crabjoe
fish6942 said:Questions regarding winter blend:
1) Is this just a mix with a higher ratio of #1 rather than #2?
2) I can get straight #1 at a local truck stop. Is there any harm in running this in my little Kubota?
Winterblend is usually just #1(Kerosene) mixed with the normal #2 diesel. There's no set ratio, and you can guess that the colder it gets the more #1 that gets mixed in. Some stations will use an anti gelling additive instead of mixing in #1.
As for running straight #1, you can do it, but I don't suggest it. It'll probably run like crap being that it has less energy and you might get detonation since it will combust at lower compressions.
If you're worried about gelling, just get some anti gelling additive. I like Howes, but Powerservice can be found almost anywhere.
