Oil & Fuel Winter Diesel Motor Oil?
   / Winter Diesel Motor Oil? #11
I'd vote for 5W.
   / Winter Diesel Motor Oil? #12
Bob, I switched to 10W-30 years ago because that's what NH ships in their tractors and because when I used 15W-30, it would be many seconds before the oil warning light would go off on my old Ford 1720. When the oil companies changed formulas a few years ago to meet the tighter automotive standards and the oil no longer became suitable for diesels, I went to synthetic and synthetic blends. My pole barn is unheated. On newer Ford and NH tractors there is a foot-long tube that transports the oil from the lower block area up to the head. That's were the sensor is and I just didn't think it was good to run for long without adequate pressure up there. I've even run on 5W-30 sythetic or blend for the same reason. My manual says both are OK and I appreciate that they get flowing quickly.
   / Winter Diesel Motor Oil? #13
The Deere dealers I've spoken to all seem to recommend the 15W-40 I've got. They just say that's what Deere says to use.
Hmm.
I suppose this all becomes moot if you have an engine and hydraulic heater installed, right?
Thanks,
Bob
   / Winter Diesel Motor Oil? #14
I've used Amsoil 15w-40 synthetic since my first 50hr change. If I remember right, synthetic oil flows better at the colder temps, even at the same weights. Do be sure to use diesel rated oil though.
Howdy,
Thanks MikePA and everyone else that answered,
It cleared up all my ?'s perfectly... :)
Gota luv this forum!!
Thanks!
John
   / Winter Diesel Motor Oil? #16
If you park your tractor in a heated garage the 15W-40 is fine. If it is not heated or you it leave outside and the temps get below 32 degrees, I would recommend the John Deere 0W-40 Plus 50 semi-synthetic oil. If you have other diesel equipment it would pay to buy the 55 gallon drum........MUCHO cheaper that way. I use the John Deere 15W-40 Plus 50. It came to about $1.29 a quart buying the 55 gallon drum. I believe it was $285.00. I use this oil in my JD 4410, Dodge Cummins, Boat engine, and Nissan. Make sure you use ONLY Fleet Gard or John Deere filters! Fleet Gard makes filters for JD.
I didn't know Fleetguard made filters for JD!
I bought an extra JD filter so I'll use that first.... but i use Fleetguard Microglass in my cummins already, would be nice to get them from one place. I get my Cummins filters at Genogarage.com
Is there a place online you can get Fleet JD filters?
   / Winter Diesel Motor Oil? #18
<font color=blue>...55 gallon drum...</font color=blue>
Wow...! /w3tcompact/icons/blush.gif
How long will it take you to use all that...? /w3tcompact/icons/shocked.gif
   / Winter Diesel Motor Oil? #19
John, the Dodge Cummins goes through about 3 gallons each change. I just changed the oil in my new Cummins - 11 quarts. So with multiple pieces of equipment, 55 gallons would only last for about 2-3 years.
   / Winter Diesel Motor Oil? #20
Shell makes a synthetic Rotella oil that is 5W-30 (I think). Wal-Mart sells it for $12.83/gallon. I'm going to use it in my Dodge Cummins, next time I change the oil.
2002 Genie S-125 4x4 125ft Telescopic Boom Lift (A52377)
2002 Genie S-125...
2024 Greatbear 72in Vibratory Roller Skid Steer Attachment (A51691)
2024 Greatbear...
CFG Industrial SAII100 (A50123)
CFG Industrial...
RCcar RC-G2.0 Electric Golf Cart, NEW! (A52384)
RCcar RC-G2.0...
2024 Dig Master DM100 Mini Excavator, NEW! (A52384)
2024 Dig Master...
11ft S/A Fuel Tank Trailer Frame (A51691)
11ft S/A Fuel Tank...
