Winter driving - weight needed in rear of pickup
   / Winter driving - weight needed in rear of pickup #11
Pea gravel,,is what I've been using past several years,,comes in 50 lb bags at lowes,,got a long bed f150,,think I had about 400 lbs in end of bed last year,,have had 200 lbs all summer,,when plastic bags puncture,,I pour them in a picneck area ,,,got a toyato,about 100 lbs works on it,,but think I had 200 lbs in end of bed on it,,6 ft bed tacoma,,,the longer the bed,,the more weight you need,,the ford has an 8 ft bed,,,both four wd.,,300 or 400 hundred lbs,,really helps,,,you can always,for a short time,,reduce air in tires,,instead of maybe 35 psi,,reduce it to say,,30 psi,,,don't do a lot of interstate driving with low tires though,,,,or,,,just put it in 4wd,,,,thingy
   / Winter driving - weight needed in rear of pickup #12
pea gravel and four 18 inch concrete blocks aren't the same thing.. I laugh at these city slickers who convince themselves that a 18" concrete block for weight will also be easily thrown under a spinning tire for traction,,, that was the jist of my earlier post
   / Winter driving - weight needed in rear of pickup #13
Pea gravel. Traction Weight.
Are not most Lowes stores located in areas the "City Slickers Frequent" ? Just perhaps they may also be informed and semi competent !
Egon
   / Winter driving - weight needed in rear of pickup #14
I get a couple of feed sacks and fill them with bank run sand and put it between the fenders and the cab. $ 3 or $4 and you could probably fill a pickup bed with bank run at a gravel yard. I fill the feed sacks in the bed of the truck and through the excess out in the driveway.
Blocks and chunks of wood are very dangerous if you had a wreck,if you hit something head on the blocks or wood could come through your black glass or who knows where else they might go.
   / Winter driving - weight needed in rear of pickup #15
When I have any traction problems I just pull the 4X4 lever back one notch. It's amazing how the weight shift of moving that little lever back 2" increases traction /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif
No weights in the back for me.
   / Winter driving - weight needed in rear of pickup #16
Egan,,,they got lowes stores up there in canada? thingy
   / Winter driving - weight needed in rear of pickup #17
i beileve thats lever brakes the laws of physics right?
   / Winter driving - weight needed in rear of pickup #18
Don't think so but we got the equivalent.
Egon /forums/images/graemlins/grin.gif
   / Winter driving - weight needed in rear of pickup #19
I bet you guys up there are real excited that my man bush got reelected,,you all are safe for 4 more years now anyways,,,thingy
   / Winter driving - weight needed in rear of pickup #20
Shuckings, we all up here been safe for ever. Just means driving slower and using the proper type and amount of weight when driving on the backcountry bush roads ehhh.
Helps to put caulks on the horse shoes too.
More info coming soon! (A50322)
More info coming...
KNOW BEFORE YOU BID - DO YOUR HOMEWORK AND BE HAPPY WITH YOUR PURCHASE (A54756)
KNOW BEFORE YOU...
2019 FREIGHTLINER M2 26FT NON CDL BOX TRUCK (A54607)
2019 FREIGHTLINER...
2009 Ford F-550 4x4 11ft Flatbed Truck (A50323)
2009 Ford F-550...
2005 Isuzu NPR Venco VC516 Landscape Dump Truck (A53422)
2005 Isuzu NPR...
2007 INTERNATIONAL 7400 DT466 SFA 4X4X CHASSIS TRK (A51406)
2007 INTERNATIONAL...
