Wishing for an AFFORDABLE PTO leaf blower
   / Wishing for an AFFORDABLE PTO leaf blower #12
Yes, that is one of the pictures from that thread.
If I remember correctly, I posted several pictures.
Thanks,
   / Wishing for an AFFORDABLE PTO leaf blower #13
Neal, very creative as usual. So the mower deck serves no purpose other than a platform for your blower?
Spence
   / Wishing for an AFFORDABLE PTO leaf blower #14
That is correct Spence,
The deck is just a frame to hold it all together.
Here is a pic of front view that shows the drive pulley on the rear of the pto shaft. I took one of the blade pulleys to use on the blower wheel. I did have to drill out the hub for the larger shaft. Was even able to make an old belt fit. Had to buy practically nothing.
Well, I guess the "crisis" (what to do with the leaves this fall) is averted. I figured for $350 it was worth my time to tinker around with the motor some more. I managed to ressurect it. A mouse had chewed thru the spark plug wire. I had replaced the magneto (with attached wire) but it still didn't run. The instructions that came with the magneto & the repair manual & how the old one was wired didn't jive. When I rewired it how the old one was, it ran. But, the carb was leaking gas. I adjusted the float & that problem seems to have gone away. Only problem now is that the machine doesn't shut off (stop wire not connected right?). I figure I should leave well enough alone untill the leaves are cleaned up /forums/images/graemlins/tongue.gif I can kill the motor by choking it at idle. I might put a stick of sheet metal near the spark plug so I can ground it.
If I had access to a welder, chop saw etc. I'd be seriously considering converting it to tractor mounted. It would only take a pto shaft, a couple pulleys, a belt and a frame to support the pto shaft & pulley. Maybe when the motor gives up for good. I checked last night, it is 19 years old.
Neal, nice work on your blower.
I still think that if someone offered a PTO Blower for $<1,000 they would be selling like hot cakes.
   / Wishing for an AFFORDABLE PTO leaf blower #16
Nice,somebody could proubally use the same principle to wun a water pump,sprayer or generator.
UNUSED MOWER KING SSFCAG Y HD HYD AUGER (A51248)
UNUSED MOWER KING...
2004 MACK GRANITE CV713 DUMP TRUCK (A51406)
2004 MACK GRANITE...
Grove 4x4 Rough Terrain Hydraulic Crane (A51691)
Grove 4x4 Rough...
Modine Shop Heater (A51573)
Modine Shop Heater...
2007 FREIGHTLINER BUSINESS CLASS M2 DUMP TRUCK (A51406)
2007 FREIGHTLINER...
2012 Honda Pilot SUV (A51694)
2012 Honda Pilot...
