proudestmonkey
Platinum Member
Egon said:Oil plug drain plug: Pretty important that it stays in place. If you have any doubts about doing it yourself get the dealer to do the job and make sure it is well documented. You may even want to invest in a torque wrench.
Just as a suggestion without proper knowledge of your tractor setup would jacking up either end and placing it on stands help your situation.
My Kubota B7100 is a charm to change oil on. All filters readily accessible and none in easily hit places. Only complaint I have is that checking the rad level or filling is a little hard with the loader on.
Yeah, I figure making sure engine oil isn't leaking out the bottom while its running is pretty important, which is why I called the dealer right away when I could neither get the plug tight enough for a seal or get it off again.
Jacking the tractor is not really necessary, although I am sure it makes things easier for the mechanics at the dealership. There was no issue with ground clearance for draining either the engine or transmission fluid, even using an oil drain bucket fully enclosed (the flat kind that has a built in cap and spout.
I have a torque wrench, and have used it already for checking and tightening the wheel bolts (I do that every 10 hours). I also use it to make sure the blades on my Kubota and my other lawn mower are properly snug.
