Hi:
The 997 just stops! Everything is running:fine diesel, hydro pump unit, the wheel motors, the hydro deck height adjusted, the blades and the safety switches including the wired seat switch and the seat delay module - which is new, and then whamo. It stops cold. It starts up again. Then it will stop again. No advance warning, no coughing, no spuddering, no warning. It stops dead.
This morning I started it up and let it run for 1/2 hour-- to check the diesel fuel from the tank in case it was clogged. No clog.
The hydro fluid temperature light cam on indicating that the fluid was over 194 degrees C. I checked with the continuity probe and it showed continuity. That indicateds that it is bad. It had less than .25 Ohms, so tomorrow I will replace it. The fluid is topped off full. Fluid was barely hot.
With the light on the hydro deck adjustment would not work, nor would the PTO, or the hydro solenoid for forward motion- nothing hydraulic workes.
With the new switch I'll check the hydro relays and make sure that they work. I think there are 4 or 5 with at least 100 wires including spliced grounds and spliced commom wires with color changes and of course the real working wires. Not JD's finest unit - community college engineers- but it made a lot off money for them, continues to do so. I wonder if anyone sued then for lack of fittness of purpose- that is cutting grass-. They would not advertize that.
It curious that there are no kill sensors on the unit but yet it stops all at once.
Oh the battery is fine, tightly connected with anticorosion protection on it, and connected to the frame with a hold down aparatious. I blow the grass clipping off it after every use.
Thanks for the help. It is appreciated.
