Wood burning shop heater
   / Wood burning shop heater #51
Easy space out ,you can use long drywall screws and cut some scrap metal conduit shims
works well...
Yep, that's what I used.
Forgot to mention, you also want an air gap at the top to allow the heated air to move upward and away from the "hot spot".
   / Wood burning shop heater #52
Im kinda needing some ideas for a wood burning heater. not realy trying to heat up the whole shop. just a place to warm my rearend while Im thinking about what toy to play with next. jb
I've used a double barrel 35 gal stove since 1972. I used bed rail to make the 4 legs. Just tack welded them to the end rims of both barrels. I don't recommend the support legs offered in the kits. if you get a lot of hot coals, the barrel sides can sag. Also, place the stove pipe collars on the ends of the barrels. This allows for cleaning the top barrel of creosote with an old hoe shaped to match the curvature of the barrel. inlet on the bottom edge of the top barrel, exit near the top. Drill all collars for self tapping screws to lock the stove pipe in place. I originally installed a damper but found this was not necessary. I doubled the end wall below the door as this is the hottest place and metal fatigue can set in here. Be sure to clean all ashes out after the heating season. I found a smaller, hotter fire cuts down on creosote as well as dry quality firewood.
   / Wood burning shop heater #53
"Cement board with a gap sounds good. My house has a fake brick panel with a 1" air gap behind the false brick. This is similar to fire resistant cement board.
Someone wrote the triple wall pipe never goes bad. The stainless steel rain cap for my stove went bad in about 8 years and had to be replaced. The inner section the mates with the inner pipe was completed corroded away. The guy at the stove shop was surprised and also thought these should never need to be replaced.
Looking at the exterior of the first section below the rain cap I see rust and pitting in that section or the outside of the exterior pipe. I sanded this and used some rust converter before re-painting it. I can see that section will also need to be replaced in the future.
   / Wood burning shop heater #54
Would someone please suggest a way to insulate the wood behind the stove...
See previous post. Thanks
When I worked at a lumber supply place in the 70's we sold hundreds of sheets of asbestos board for just that purpose. One of the builders told me he prefered it to sheet metal as it cut much easier with a Skillsaw. He was a 3 pack a day man, if I remember right.
2015 Honda Odyssey VAN (A51694)
2015 Honda Odyssey...
Unused Delta Crash...
2018 FORD TRANSIT T250 CARGO VAN (A52577)
2018 FORD TRANSIT...
Chevrolet Silverado 1500 Crew Cab Pickup Truck (A52377)
Chevrolet...
2003 CATERPILLAR 277 SKID STEER (A51246)
2003 CATERPILLAR...
2019 FORD F-150 XL SINGLE CAB TRUCK (A51406)
2019 FORD F-150 XL...
