Wood Fence posts for the garden
   / Wood Fence posts for the garden #1
cmhyland
Platinum Member
Woodstock Valley, CT
2000 Kubota B2910
I've been looking around for fence posts to fence in the garden. Everything you find is some form of pressure treated and that stuff is nasty. Anyy thing rated for direct burial is CCA Cromium Copper Arsenate...
I looked at Cedar and at 40 bucks a post that is out. I think I'm going to the sawmill and duglas fur posts and I'mm paint the bottoms. The other option is to charr the bottoms of the post.
Anyone got any ideas?
Thanks,
Chris
   / Wood Fence posts for the garden #2
Liquid rubber has been a recent popular coating for posts; how many posts are we talk'n about?
   / Wood Fence posts for the garden #3
You sure it is really CCA and not ACQ?
There is nothing wrong with CCA unless you breath smoke from burning CCA or chew on the treated wood. I WISH I had CCA in the house instead of ACQ because ACQ reacts strongly with metal and requires either thick galvanized metal fasteners or stainless steel. Us the wrong type of fastener or metal on ACQ and the metal will rot.
You will spend a fortune buying wood that has natural resistance to rot. People say to use Eastern Red cedar, which I have plenty of on my place, but in my soil, the stuff rots. Wood rot I have seen is at the ground and air line. If I put anything in the ground that I want to last, it has to be PT at .4 other wise it will rot. Just a mater of time.
There is an article in the last issue of Independent Sawmill and Woodlot magazine on how to treat your own posts. Sounded like a lot of work and trouble to me.
Later,
Dan
I'm estimating about 32 posts.
I think the liquid rubber might be costly.
Regards,
Chris
   / Wood Fence posts for the garden #5
Steel pipe?? I just did my garden using steel I had. 2-3/8" and 2-7/8" Drill stem pipe is real popular here (Texas) for fence, as is telephone poles, railroad ties.
Later,
Dan
Dan,
You don't want CCA anywhere near your veggies... the Arsenic leaches into the soil and it is inorganic arsenic. Organic arsenic your body will process over time and get rid of it.
Inorganic Arsenic is something that get trapped ino your body and it never leaves your body.
The other possibility is I have a bunch of black locust trees and I may cut them and get them milled into posts. Black Locust gets so hard it will outlast pressure treated wood in direct burial.
The old yankee farmers used to say it would last 3 days longer than stone.
Regards,
Chris
Dennis,
In that same idea, 4 in PVC filled with concrete with a cap...
Regards,
Chris
looking at the cost of PVC I think it ends up being too expensive and is at PITA to attach things to it.... The old timers used to char the bottoms of the post.... they'd start a fire and toss the butt end of the posts in and char the first 3 ft.
Regards,
Chris
   / Wood Fence posts for the garden #9
Go with the locust. When I was growing up, my grandfather and father always used smaller locust for fence posts (about 6" for line posts, 10' or so for corner posts)
There are still a bunch of them that were set before I was born that are still there today. They always cut them way before they planned on needing them. Papaw said if you set a locust post while it was still green, it'd keep growing shoots!
I need to put in a short fence this summer so I cut the locusts last year and air dried them. As soon as it gets dry enough to dig the holes, I'll strip the bark off them and plant them. I'd also bet that by the time they need to be replaced, I won't be around to worry about it!
   / Wood Fence posts for the garden #10
Dennis,
In that same idea, 4 in PVC filled with concrete with a cap...Chris
I have seen that, also have seen larger poured concrete post, but I think by the time you add the cost and work involved???
Regards,
Dan,
Regards,
Chris
Well there you go! cheap, accessible and as good as you'll find (especially for the price). I was thinking of the corners and gate ends for pipe/tubing. I use "T" post for line post.
   / Wood Fence posts for the garden #11
I've had redwood posts in my garden for a number of years. They haven't rotted yet.
   / Wood Fence posts for the garden #12
We use steel or untreated cedar. The cedar are almost 20 years old and still in good shape so I don't care if they eventually rot out. Better than chemicals in my soil! Steel is great though between the cedars, or put a steel post in and "face" it with a cedar post that doesn't actually go into the ground.
   / Wood Fence posts for the garden #13
Regards,
Chris
I'm 36, and there are some locust posts my Dad set on the back of the property around the time I was born. They're still there, but the fence is long rusted away. Once locust seasons out, good luck driving a fence staple into it. It's a lot of work, but if the diameter is too large, they can be split. I recently cut some locust trees that were too large for corner posts and split them. Cut them whatever lenght you want. You'll need a sharp wedge and start at the small end. Usually there is a visable split, put your wedge on the split. Drive the wedge in as far as it will go, once it cracks, you can use duller wedges down the length.
You can also use cedar which last a long time, but not as long as locust. It's also a lot easier to drive fence staples in.
   / Wood Fence posts for the garden #14
If they're available in your area, get some Hedge (Osage Orange). They get hard as a rock & will last 50+ years! ~~ grnspot
   / Wood Fence posts for the garden #15
Dan,
Regards,
Chris
Very little CCA leaches from the wood and what little does leach does not go far in the soil. To leach out of the wood, the wood and soil would have to be wet, and even then CCA just does not go very far, the plant roots would have to then take up the CCA for us to consume the chemical. I researched this years ago during the big CCA scare and the chance of me being poisoned by CCA PT is about zero. I built and used CCA PT for raised beds and nobody got sick. One day we will put up a proper fence around the garden and the posts will be .4 ACQ since I only want to build the fence once. I would use CCA without a worry if it was still sold locally.
The only reports I could find on anyone getting sick from CCA were people/animals eating the wood or burning the wood. DUH!. Other reports were very iffy if the CCA even was at fault. Even counting the iffy reports, there were danged few people reporting problems and this was on an anti CCA website. I would have expected thousands of reports but they had a few dozen.
The EPA report on banning CCA I read was sad to say the least. In that big long report they never said CCA WOULD or WILL hurt someone. They always used the words like MIGHT and COULD.
PT wood is used in the vast majority of wood frame houses that have been built for many decades.
In any case, while CCA is still available, it is hard to find and most PT wood is ACQ.
Your choices are simple. Use a PT wood for long life, use untreated wood that is not rot resistant, or use naturally rot resistant wood which is usually expensive. If you have local and cheap rot resistant wood you are lucky. We do not. My neighbor used Easter Red Ceder to build a small pole barn which is now falling down. He got a couple of decades out of the barn but now he has moved into a home and has to sell the house. That danged barn is a serious safety hazard and I can't believe they have not torn it down. The danged thing is leaning at a good angle and the liability is huge. If he had spent a few hundred dollars on the posts the barn would be in great shape and an asset to the property but since he went cheap and that barn will have to be taken down since it is a liability. It will cost them more to take that barn down that it would have cost to have bought PT wood in the first place...
Later,
Dan
   / Wood Fence posts for the garden #16
Do you have forest service land around you?
It has been a while since I've done it, but around here the forest service charges something like $1 per post for personal use.
The only catch is that it has to be "down wood"... and you have to do a little work cutting, splitting, and dragging it out of the mountains.
Mom had a cousin in the forest service that would tell us where to look for down cedar.
13' ROLL OF CARPET (A60432)
13' ROLL OF CARPET...
2023 CAN-AM DEFENDER RTV (A59823)
2023 CAN-AM...
2018 Husqvarna 21in. Push Mower (A59231)
2018 Husqvarna...
2020 Deere 750K LGP (A53317)
2020 Deere 750K...
2020 CATERPILLAR 299D3 XE SKID STEER (A60429)
2020 CATERPILLAR...
2020 CATERPILLAR 303.5E2 CR EXCAVATOR (A60429)
2020 CATERPILLAR...
