Wood Splitter Cylinder Quit Moving...
/ Wood Splitter Cylinder Quit Moving... #21
I was not able to get a gear puller in on top of the pump as it was attached to the inlet and outlet lines. Had I known the shaft would break so easily, I would have drained the hydraulic fluid tank and disconnected the lines to the pump, removing the pump from beneath the splitter and worked with getting the coupler off the shaft from on the workbench. Yes, the pickle fork is intended for tierod ends and smaller ball joint separation tasks.
I was able to use a gear puller on the upper coupler half attached to the engine (1" diameter) driveshaft. After the same heating, penetrating oil, heating, etc....the coupler half pulled off the shaft without too much effort.
DL Meisen,
Thanks for the source of a replacement pump. From Surplus Center
I'm considering the #9-7503-16 pump.
I would like to know if it is a cast-iron or aluminum bodied pump. Any one know if it is or not?
Any idea if it is USA-made?
BarnieTrk
Probably best to inquire directly to Surplus Center...
Dale
2014 Kia Sedona Van (A59231)
2014 Kia Sedona...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
Deere 333G (A53317)
Deere 333G (A53317)
2023 Kubota M4-061 Deluxe MFWD Utility Tractor with LA1154 Front Loader (A55315)
2023 Kubota M4-061...
(1) 300 GALLON POLY TOTE W/CAGE (A60432)
(1) 300 GALLON...
2019 KENWORTH T680 TANDEM AXLE SLEEPER (A59904)
2019 KENWORTH T680...
