Wood Splitter/ Spool Valve set up questions w/ pics
   / Wood Splitter/ Spool Valve set up questions w/ pics #1
kootenai
North Idaho
'07 Kubota L3400. Woods: Tiller, Back Blade, Box Blade, Backhoe
I have a L3400 Kubota. I used to use my wood splitter with a Ford 3000. I ran it off the FEL spool valve. I have converted the quick connects to fit my Kub FEL spool valve but am uncertain of the configuration. In the past I have had to hold the valve open with a bungee and will have to do that again with this configuration. Where does my inlet and outlet hose hook to the spool valve?
   / Wood Splitter/ Spool Valve set up questions w/ pics #2
You need to attach LS hoses the the fittings on FEL valve that are mates for the same spool. I would utilize the bucket control spool.
Thanks TX, I will ask you to be more specific. For instance, do I put the inlet to the LS on the top left or top right or bottom left or bottom right of the spool..... Dumb it down if you would.
   / Wood Splitter/ Spool Valve set up questions w/ pics #4
Left or right only top or bottom only are two different spools.
David Kb7uns
   / Wood Splitter/ Spool Valve set up questions w/ pics #5
I agree with David
Thanks guys
KSI Conveyor (A55301)
Kubota RTV-1140 4x4 Diesel Utility Cart (A55851)
Kubota RTV-1140...
DEUTZ MARATHON 60KW GENERATOR (A55745)
DEUTZ MARATHON...
2014 Ford F-150 Ext. Cab Pickup Truck (A55788)
2014 Ford F-150...
2013 POLAR TANK CRUDE TRAILER (A55745)
2013 POLAR TANK...
