How would you control the damper?
Manually. When you light the stove open the damper. When you're not using the stove, close the damper.
Too hot for what? The temp at the heat exchanger in the furnace is a lot higher than the temp on the ceiling above a stove.I am ventilation expert I do not recommend doing this because temperature from wood stove is to hot
The ceiling above the stove is made out of drywall, why does the ductwork need to be more fireproof than the drywall?and the next question is Is your return air space made of combustible material or completely lined with sheet metal
Only true if there are no supply ducts in that area and the room is relatively sealed.also the forced air systeme will bring the room under negative pressure
That's what happens every time the furnace cycles.And if it's lined with sheet metal it can make noise because it expending do to the heat
BeezFun said:Too hot for what? The temp at the heat exchanger in the furnace is a lot higher than the temp on the ceiling above a stove.
