Wood Stove Rebuild
   / Wood Stove Rebuild #51
WOW - This thread is just what I was looking for, thank you so much Lloyd, Keegs, IrvinJ and everyone else for describing your rebuilds in such detail. I'm so glad the posts are recent and current. In this post, I'm asking about parts, advice, and outside air-attachment experience.
I bought my VC Resolute III 0042 on craigslist four years ago for $250. (a point of pride, I love this thing!) It's my primary heat source. (fuel: oak, cherry, poplar, maple, sycamore. Also: I have steady supply of wood palettes I cut up and burn.)
I found this site by searching for VC Resolute III 0042 replacement parts. I need to rebuild/clean mine. It still works nicely, but there's cracks in the side panels and fireback and the gaskets needs replacing.
I'm going to hunt for the parts at the sources mentioned in this thread and see what kind of luck I have. Any updated guidance would be appreciated!
Recommendations on gaskets kits would be appreciated too. This stove has been very good, and I hope to get many more years out of it. At the end of burn season (S. NJ=mid-March), I plan to do a complete rebuild.
Also, my house is very tight due to a recent rehab: new windws/doors/closed-cell-foam insulation throughout. The draw from the fire pulls the cold air up from the basement. Does anyone have experience rigging an outside air feed to the Resolute I/II/III? Or any advice?
Here's the list of parts I'm looking for:
Resolute III 0043 Exploded Parts :
33 1200521, (quantity 4)
26 1200811 (quantity 1)
30 1200848 (quantity 1)
9 1301784 (quantity 1)
20 0004444 (quantity 1)
32 1201338 (quantity 2)
CB1000,
Glad it was helpful... TBN is a wonderful source not only for tractor info but general living info as well. By that list and the prices attached to it you might be better off finding a better used stove than the once you have and changing pieces to build one good one.
Best fo luck...
CB1000,
Best fo luck...
Bob Villa had a short video showing the assembly of a stove at the plant... good info.
   / Wood Stove Rebuild #54
Well, I still have yet to start my rebuild...:ashamed:
But you're right, some great info on this forum!
   / Wood Stove Rebuild #55
...Also, my house is very tight due to a recent rehab: new windws/doors/closed-cell-foam insulation throughout. The draw from the fire pulls the cold air up from the basement. Does anyone have experience rigging an outside air feed to the Resolute I/II/III? Or any advice?
When I bought our Resolute Acclaim 0041 back in the early 90's, I also ordered the outside air kit supplied by VC. It is just a sheet metal pan that bolts to the bottom of the stove with a 3" connector to hook up to your cold air supply. There's nothing really airtight about the connection, though. I could send a photo or photos if you like.
I bought to kit because the stove was going in a new addition that I thought would be very airtight. Then we put French doors between the room the stove is in and the old part of the house.
   / Wood Stove Rebuild #56
Took a trip up to the farm this past week to assemble and install the wood stove.
Putting together six sides of the stove plus the inside castings with just two hands wasn't easy but after several attempts I found "a" way. I took the feeder door off the top plate and laid the top plate inside up on the floor. I then assembled the fireback to the back plate and with the threaded rods attached to the top plate I put the 4 x side panels on and then attached the bottom with the nuts. I then assembled the side castings and the ash fettle.
I used a 1" putty knife to pack the cement into the joints which seemed to better keep the cement in place while struggling (understatement) with the assembly.
Here's the stove assembled with the new fire back and side casting:
http://i829.photobucket.com/albums/zz215/keegsbucket/_042611_1658a.jpg
I put down some durarock and some ceramic tile for a hearth. The brick back is set about 1.5" from the 5/8" sheetrock.
http://i829.photobucket.com/albums/zz215/keegsbucket/_042611_1705a.jpg
I bought some new 22 gage 6" stove pipe. The top of the older Resolutes (not sure about the newer Resolute Acclaim) have an oval flue section. The round stove pipe forms just the right size oval when you form it into the flue section.
I didn't have the owners manual with me so I was guessing how to operate the vents. (there's two on this one) I'm also going to replace the steel door panel inserts with fire glass so I can view the fire burn.
It's like a brand new stove.
Thanks again Lloyd for the example.
   / Wood Stove Rebuild #57
I also have a Resolute I II and have been following this thred. My fireback baffle has a crack and will need to be replaced before I use it this winter. I had a place bookmarked for the part but have found the the part is no longer available. I did find a rear baffle for a Resloute III mine is a Resolute I II , Can anyone tell me if this will work or a place I might be able to find the part?
Thank you
   / Wood Stove Rebuild #58
Thank you
Not sure about your stove, but as far as finding it i would just start using google and yahoo.
   / Wood Stove Rebuild #59
Great thought and I have without any luck. That's how I found this site. I know this is going to be a tough one if parts are no longer being made as this seems to be the part that wears out the most. I guess I'll keep searching.
   / Wood Stove Rebuild #60
Have you contacted the company directly and asked them? Here is their website. A phone call would be easy as well. Located in Vermont.
Vermont Castings | Customer Care
Good luck. Really nice stove! American made.
BOMAG BW145D-40 SMOOTH DRUM ROLLER (A51246)
BOMAG BW145D-40...
HYUNDAI HX235 LCR EXCAVATOR (A51246)
HYUNDAI HX235 LCR...
40' CONTAINER (A51248)
1984 ASPT 30ft Pole S/A Towable Trailer (A51692)
1984 ASPT 30ft...
CAT Skid Steer (A50322)
CAT Skid Steer...
Pallet of (4) 10 Lug Misc Wheels (A51573)
Pallet of (4) 10...
