Woodchipper Recommendation
   / Woodchipper Recommendation #1
IronCladChad
TYM T474
Anyone have a good woodchipper recommendation for my t474? I sold my Bearcat before moving to WV. I'm up against a lot of autumn olive, vines, and thick bushes. Anything over 6" is firewood unless it's punky. I'm hoping for some January sales.
   / Woodchipper Recommendation #3
I have a Woodmaxx 8H. It's been pretty good. Woodland Mills also offers an 8" chipper which is a different design. There are some good points to that design and to the Woodmaxx.
Even if you burn anything over 6" an 8" throat would be a minimum. It will let you chip material that isn't straight or has branches. I don't often chip stuff over 4" these days but would not want a smaller chipper.
Chipping larger material takes HP. Even with the feed turned down all the way my tractor will run out of steam on 6" stuff. I need to stop and start the feed.
Speakin of feed, hydraulic power feed is the way to go. It's safer than manual feed which grabs the branch and sucks it in unpredictably, and you can adjust the feed rate unlike mechanical feed. It only costs a little more but it's so worth it.
   / Woodchipper Recommendation #4
I am Curious on how well a chipper works on vines. Do they feed in or turn into a tangled mess?
   / Woodchipper Recommendation #5
I think that feeding vines and smaller stuff works best if accompanied by some larger limbs etc.
Cheers,
Mike
  • Good Post
Reactions: JJT
   / Woodchipper Recommendation #6
That's been my experience with any of the stringy stuff, need to feed in a good chunk to clear the throw-out chamber or else you're stopping and cleaning out a jamb -- which is not fun!!
   / Woodchipper Recommendation #7
I had a 6" Vermeer 606 PTO chipper. It was about the heaviest duty model I could find, it had a 6x6 opening and was hydraulic feed. A lot of times if I didn't trim the larger branches or small trees just perfectly, a branch would get hung up in the feed and I'd have to back it out.
I think Wallenstein's design with the 6x12 opening for the 6" chipper is a better design, although I have no personal experience with it, I could absolutely guarantee that I would have had a lot less hangups if the Vermeer was similar.
I sold mine, it ended up being way more work than it was worth. Now I just grapple the brush into a pile in the woods, or burn it.
I've learned my lesson when burning. Out of no where the breeze picks up and the fire takes off and looks like a portal to satan is opening. I also use all the wood chips to smooth out a path over all the clay.
  • Good Post
Reactions: JJT
   / Woodchipper Recommendation #9
Yes. I have a mostly pine forest. Burning has its place, but big fires are just asking for trouble. Wood chips can be used many other ways, too. My place is big enough that I could put the vines and such in a remote pile/pit and let them decompose over time. I'll burn logs and chip branches.
   / Woodchipper Recommendation #10
Vines and trees that tend to shred and become stringy like dogwood and willow are a PITA. For me they wind up inside the chipper housing and eventually jamb into place.
You need sharp knives and your anvil adjusted tight, feed slow and make sure the chips coming out match what's being fed.
   / Woodchipper Recommendation #11
Oh, BTW, I've used the Woodland Mills WC68 for hours and hours now...since 2019. The machine has been trouble free. I've run mostly cedar, pine, redbud, poplar, walnut and some bush trimmings occasionally.
Cheers,
Mike
   / Woodchipper Recommendation #12
Ditto on the Woodland Mills WC68. Mine has been chipping for 3 years. I haven't needed to even flip the blades yet but will soon. Most of my chipping is pine and sweet gum with a generous mix of vines. I think Woodland wil resharpen a set of blades for around $15, but I bought a spare of new blades back then, so there's no rush on that.
   / Woodchipper Recommendation #13
Another thumbs up for the woodland mills wc68. I'm chipping mostly oak.
   / Woodchipper Recommendation #14
I have a Victory 8H which is basically a clone of the Woodmax or Woodland Mills 8H. There are some small differences but nothing really significant imo. Mostly purchased the Victory because, at the time, the wait time for either of the other brands was too long for my needs.
Been pretty satisfied with it- chips everything I have put through it. Definitely get a hydraulic infeed machine you’ll never regret it.
   / Woodchipper Recommendation #15
Very happy with my Woodland Mills WC68. Although, I don't have a lot of hours on it.
   / Woodchipper Recommendation #17
I would look at Split-Fire made in Canada, I have their wood splitter and the materials and workmanship are very good. They make a wood chipper and ship with very reasonable rates. If I were in the market I would look at their products. Customer service is very good as well.
They are gravity fed which would be a pain feeding in brush.
Update: I got a Woodland Mills Wc68 locally for $2500 delivered from fb marketplace. I'm waiting for decent weather to try it out. Now I need to find a grapple with grease zerks. The cheap ones don't have them..
   / Woodchipper Recommendation #20
For the average homeowner, I'd imagine that the WC68 would last one's lifetime.
Cheers,
Mike
20FT X 30FT STEEL CARPORT (A58214)
20FT X 30FT STEEL...
CAT 312C EXCAVATOR (A58214)
CAT 312C EXCAVATOR...
2016 CATERPILLAR TL1055D TELESCOPIC FORKLIFT (A60429)
2016 CATERPILLAR...
2008 INTERNATIONAL MA025 FLATBED (A55745)
2008 INTERNATIONAL...
2016 Dodge Grand Caravan SE Plus (A59231)
2016 Dodge Grand...
1989 AM General M998 HMMWV 4x4 Humvee Truck (A59230)
1989 AM General...
