3-Point Hitch Woods 1050 on a Kubota L48
   / Woods 1050 on a Kubota L48 #21
How do you guys dig in a tight space??
Carefully. Sorry, but no easy answers here, Jerry.
Did you make a subframe that ties into the Kubota's 4 attachment points? I would
like to see a photo of the hoe-side of your subframe when the hoe is dismounted.
Tractor and backhoe are over at the work site so I should be able to take pictures on Wed or so. The backhoe is mounted just like a Kubota backhoe. I bought the clamshell grips and built the rest. The only thing I don't like is how the bottom posts just rest on the open hook. They do carry weight, but sometimes click and clack as the move a little.
I am happy with the result. I really should have painted it, as it is now rusting. Perhaps I will use the sandblaster on it the next time I have it out.
Jerry
   / Woods 1050 on a Kubota L48 #23
You bought Kubota's clamshell grips? What did that set you back?
Yeah, there is going to be some looseness in the mount, like my B21's. That's the price
you pay for the quick attachment ability. Woods uses bolts (as do I) for the upper
attachment to reduce this wiggle. They even provide a wrench in a slot right on the
subframe.
I got the backhoe cheap so I was willing to spend some on the attachement. The clamshells work great , it is the bottom where the large pegs just sit on the hook. I think the design (by me) was to put a chain around them, but once the hoe is on, it is hard to get back there. So I have not done anything since it works and I can get the hoe on and off in about 15-20 min. It would be faster , but I don't do it often enough to remember the right steps.
You should see my brush hog, which I put on the front of the tractor. Another micky mouse job, but it works.
Jerry
   / Woods 1050 on a Kubota L48 #25
I know this is an old thread but because these 3 point hoes are popular attachments, I thought I'd add my 2 cents. I've got a Ford 6600 with a Woods 1050 attached. It makes a great deal of power. It will snap three or four inch roots without drama and will dig trench or hole quickly and cleanly. It has a float feature on the boom that is SUPER handy. Allows you to scrape an area flat or put a flat bottom on a trench. The hoses are intelligently routed, the valve is modern and a two-stick type. The operator is protected from burst hoses by a shroud that covers all of them. Mine has the PTO pump which works very well. I run it at about 1200 RPM and it is quick enough and powerful enough for most projects. I have never run it up to 1900 RPM which is where my 6600 hits 540 on the PTO. At low RPM, it works just fine and is quiet enough that I'm relaxed.
I don't know about other tractors but my 6600 handles it well. The 6600 is an updated 5000. Heavier and more powerful. Full cab, large FEL, loaded rears. I have no complaints...the combination is powerful and when I'm done with the hoe, I can put it in the corner of the barn and not worry about yet another battery, clutch, diesel pump, tires, brakes, hydro pump, and on and on and on. It is a good solution unless you need a true backhoe or excavator. I'd like to be able to swivel the seat from hoe to tractor but, all things considered, for using a hoe once or twice a month, I can live with it. The 3 point system is mildly difficult to mount but nothing to get in a tizzy about.
The 3 point system on mine seems very solid. I'm not sure even abuse could break anything on the tractor. Maybe...but the two lift arms are 1" thick, the Saf-T-Lok system is 1.5" thick and the toplink bolt is a class 5 and 1" in diameter. Sure, I could build a home-made four-point but for my needs I won't bother. I will say that I would NOT mount such a backhoe on any tractor with an aluminum rear end assembly. I don't think I'd want a 3 point system on a "compact" tractor either. Just not enough mass there, IMO. But if you have a 50 hp and up Ford or Deere or maybe a 175 Allis or MF, I'd go for it. I also own a Kubota L3130. It is a nice utility tractor but it does not have the beef to handle a hoe the size of a 1050. Nor would I mount any hoe on it without a subframe. My opinion only but the small backhoes suitable for that size tractor are OK for residential use but not enough machine for farm use. Just my opinion.
BTW, it will dig 10' 6" deep...more than enough for even a basement and will bury the largest cow to the legally required depth.
So, in summary, as long as you match the tractor to the size of the hoe and don't try stupid backhoe tricks or lose patience removing tree stumps, you'll be happy with a 3 point hoe. With small tractors, a subframe would be a reasonable addition and essential for any machine with aluminum parts.
2013 Doyle Dry Fertilizer Tender Trailer - Kubota Diesel, 3 Stainless Compartments, Side Discharge (A53472)
2013 Doyle Dry...
2003 Ford Excursion 4x4 (MPV), VIN # 1FMSU43PX3EC07978 (A51572)
2003 Ford...
JOHN DEERE 5075E (A53084)
JOHN DEERE 5075E...
2011 New Holland Boomer 90 MFWD Utility Tractor (A53472)
2011 New Holland...
2019 RBR Venturi 380 (A53472)
2019 RBR Venturi...
2008 Ford F-550 Flatbed Truck (A52377)
2008 Ford F-550...
