Woods Blade
/ Woods Blade #1
mccjarrowe
We have a 6' woods blade and want to buy the attacments to turn it into a box blade...has anyone ever done this?? is it worth it or should we look for a box blade also??
/ Woods Blade #2
I believe there are side plates that are available for carrying more of a load, although I am not sure if they are available for a smaller 6' blade.
A box blade is designed to be able to immediately push or pull material. A rear blade will have to be manually reversed.
A box blade also has scarifier teeth to loosen up earth which a rear blade won't be able to duplicate. A rear blade tends to go right over hard packed dirt, at least the lighter ones. I own 2 seven footers, and a 1000# hydraulic nine footer.
With the 9' unit I have to be careful as it will dig into things. It will easily peel up asphalt if given the chance.
A rear blade really shines for windrowing material, especially on a long driveway.
It will also perform simple ditching say along the side of a driveway.
It is common to use a rear blade for winter plowing, but I have to say I don't recall seeing too many people using a box blade for snow.
While it will work for grading, a box blade will usually work better.
If you can swing it, and can justify the purchase, add a box blade to your collection.
/ Woods Blade #3
I have the side plates for a Woods 6' blade. I use mine for snow removal. I don't think it would work well as a box blade. Unless you are moving loose soil. Digging with the side plates on would be hard. You can see some pics of the plates in my photo gallery.
Solo
/ Woods Blade #4
As GE222 said, if you can swing it, get a box blade. These are two different animals, each being good for their designed purpose. Plus for what the side plates for the rear blade cost, for 2 or 3 times that cost you could get a lower end box blade.
If you are only moving soft material, then the end plates would work fine.
Always better to have more implements if you can though.
Good luck
/ Woods Blade #6
Carykong
"you can never have enough attachments"
AMEN to that. :)
2021 ISUZU NPR (INOPERABLE) (A63569)
2021 ISUZU NPR...
2023 Takeuchi TL6R Compact Track Loader Skid Steer w Low Hours (A63118)
2023 Takeuchi TL6R...
Hr:1033.8 (A61572)
Hr:1033.8 (A61572)
1990 INTERNATIONAL 3800 DAY CAB DUMP TRUCK (A58214)
1990 INTERNATIONAL...
2018 Kia Forte Sedan (A61569)
2018 Kia Forte...
2001 John Deere 1760NT Planter (A63109)
2001 John Deere...
