Woods Blade
/ Woods Blade #1
mccjarrowe
We have a 6' woods blade and want to buy the attacments to turn it into a box blade...has anyone ever done this?? is it worth it or should we look for a box blade also??
/ Woods Blade #2
I believe there are side plates that are available for carrying more of a load, although I am not sure if they are available for a smaller 6' blade.
A box blade is designed to be able to immediately push or pull material. A rear blade will have to be manually reversed.
A box blade also has scarifier teeth to loosen up earth which a rear blade won't be able to duplicate. A rear blade tends to go right over hard packed dirt, at least the lighter ones. I own 2 seven footers, and a 1000# hydraulic nine footer.
With the 9' unit I have to be careful as it will dig into things. It will easily peel up asphalt if given the chance.
A rear blade really shines for windrowing material, especially on a long driveway.
It will also perform simple ditching say along the side of a driveway.
It is common to use a rear blade for winter plowing, but I have to say I don't recall seeing too many people using a box blade for snow.
While it will work for grading, a box blade will usually work better.
If you can swing it, and can justify the purchase, add a box blade to your collection.
/ Woods Blade #3
I have the side plates for a Woods 6' blade. I use mine for snow removal. I don't think it would work well as a box blade. Unless you are moving loose soil. Digging with the side plates on would be hard. You can see some pics of the plates in my photo gallery.
Solo
/ Woods Blade #4
As GE222 said, if you can swing it, get a box blade. These are two different animals, each being good for their designed purpose. Plus for what the side plates for the rear blade cost, for 2 or 3 times that cost you could get a lower end box blade.
If you are only moving soft material, then the end plates would work fine.
Always better to have more implements if you can though.
Good luck
/ Woods Blade #6
Carykong
"you can never have enough attachments"
AMEN to that. :)
2019 HINO 195 18FT 4X2 S/A REFRIGERATED BOX TRUCK (A59910)
2019 HINO 195 18FT...
2025 Swict 78in. Bucket Skid Steer Attachment (A61572)
2025 Swict 78in...
2017 Jeep Patriot 4x4 SUV (A61574)
2017 Jeep Patriot...
KOMATSU Dozer PC (A64047)
KOMATSU Dozer PC...
2012 VOLVO DBL SLEEPER ROAD TRACTOR (A62130)
2012 VOLVO DBL...
2011 ORTEQ TANK MANIFOLD (A63569)
2011 ORTEQ TANK...
