Woods RFM used with iMatch???
   / Woods RFM used with iMatch??? #1
jmt1271
Platinum Member
MO
Kubota L2501
I just bought a used Woods RM550. I will be using it with my 3520 with iMatch. I am trying to find out if I need any kind of mounting kit. Does anyone know? Any feelings on the Woods RM550? Ideas on a fair price for a used but in real good shape unit?
thanks.
   / Woods RFM used with iMatch??? #2
You will need a Woods quick hitch adapter to use the I-Match.
I bought a lightly used Woods RD 7200 mower today, and also looked into using I-Match.
Local NH dealer who sells Woods didn't have any idea what I was talking about.He finally found the adapter kit listed in the book after I showed him the info on the Woods web site. List was $126. I don't know if the 550 takes the same kit as mine.
Paid $1400 for the mower BTW. I don't think it had even ten hours on it.
Regards,
Jon
   / Woods RFM used with iMatch??? #3
That Woods kit should be good for all Woods RM & RD series mowers. Like I said before, if you wanted to save $100 you could probably use the LandPride Floating Top Link Kit, however, it's not quite as slick as the Woods kit. If you don't mind the extra $100, I would definitely go with the Woods Kit.
By the way, make sure you post pictures of the mower and the kit once you have it. I really want to see one of these kits installed.
I am supposed to pick up the mower on mon. I will post pics.
   / Woods RFM used with iMatch??? #5
By the way, the part number for the Woods RM/RD Quick Hitch Kit is 1005400 and it lists for $126.
   / Woods RFM used with iMatch??? #6
I guess I don't quite understand why you want to use I-Match with the Woods RFM, as it is one of the easiest things to hook up. I've got an RD 7200, and it maybe takes me 30 seconds to hook it up. (the PTO takes the longest and nastiest because of the grease.
Sure, I-Match is great for really heavy implements (like a box scraper) that are hard to line up, but it is overkill for a mower.
Just my 2 cents....
Jeff
   / Woods RFM used with iMatch??? #7
Jeff,
The mowers have wheels so they are easier to hook up, however, it's time consuming if you have to remove the iMatch to use the mower and then put it back on for the other implements. If you have an iMatch, it's much easier just to go the extra mile and make everything iMatch compatible. I have done just that and I love it! It's a real time saver.
   / Woods RFM used with iMatch??? #8
Neophyte - was your landpride rake Imatch compatable? How did you modify it?
Neo, can you tell me where to find the woods kit that will make my RM550 iMatch compatible. Cant find it on Woods' site.
John Deere Ztrak M665 60in Zero Turn Mower (A48082)
John Deere Ztrak...
Brown BDH-750 Disc Harrow (A50490)
Brown BDH-750 Disc...
CFG MH12RX Mini Excavator (A49461)
CFG MH12RX Mini...
2024 BCL Fabrication Landscape Dump Trailer - Heavy-Duty Utility Trailer for Mulch Debris Hauling (A50397)
2024 BCL...
Land Honor Skid Steer Utility Hitch Adapter (A50515)
Land Honor Skid...
2001 Club Car Carryall Utility Cart (A51691)
2001 Club Car...
