Work shop
/ Work shop #1
kennesm
Paradise, TX
None
I need to start planning and saving to build a shop. I'm looking for suggestions? I live in north central Texas and most of what I see these days are metal but there are still a lot of old pole barns standing on farm land. My biggest question is should I go with a metal or wood structure? I'm not too picky; I will just be using it as a work shop and storage. Does anyone have some good cost saving ideas?
/ Work shop #2
I think the choice between metal and wood is a personal choice.
and some on how the building will be used and constructed,
full floor or not, if a perimeter ring foundation, or just posts
if the interior is to be finished, or not
insulation, and if the insulation is to be done during construction or after,
if your hiring it built or a DIY project, and what experience and equipotent one has, and help.
the size of the building,
if it is to be heated or cooled,
may be a little more info on what your thinking may help,
/ Work shop #3
I live a couple hundred miles north of you, so this should work there also.
Big doors on north and south, for summer air flow, with big concrete pads outside.
Have a walk in door where our rare ice storms won't freeze it closed.
Insulate first.
Wood works for me, had it built by a professional pole barn builder, 30x40 plus the shed.
/ Work shop #4
These folks advertise in our local Montague County Shopper paper. They seem to be reasonable in price, especially for basic structures. They are out of Seminole, Oklahoma just east of Norman, OK.
/ Work shop #5
Insulate first.
View attachment 313969 View attachment 313970 View attachment 313971 View attachment 313972 View attachment 313973
Now that's what I'm talking about. I'd love to have one like that. If you don't mind me asking, how much does one like that cost to have built?
/ Work shop #6
I had this one built about 4 years ago for $25,500. It is completely wired with 100 amp panel, 110v and 220v for my welding machine. 110v receptacles are wired every 8 feet inside and one set under each shed along with light fixture It is 2x4 x 9 foot studs setting on a coarse of 8" CMU blocks and fiberglass bats in the walls and roof with 3/8" plywood interior walls and 1/2" exterior walls. Galvalume roofing, 2 insulated 8 foot tall doors, one 16' and one 10' wide plus a man door opening into the bathroom on one side. It is 30x30 concrete slab with 12 foot sheds on each side(30x52 under roof). Also the attic is floored and lighted in the 15 foot section down the middle with a pull down ladder for access. I have 6 fluorescent fixtures with double 4 foot tubes which lights it up well. I also have a double bulb spot light at the side by each garage door for when I need some more light. Last year I added a 14 x 30 shed on the back side of this structure to house my boat and lawnmowers, fuel tank and fishing gear so I had more room to work inside the original shop. I didn't insulate it but now I wish I had because it really gets hot whereas my shop stays cool in summer and warm in winter. I can heat it comfortably with a 1500 watt heater and cool it with a 15K BTU window air conditioner.
/ Work shop #7
$19k in November, 2011. The doors are 12x12 and skylights are in the wall, not in the roof.
/ Work shop #9
My pole barn went up in 07 I was in the $19K range also for a 30x40 with concrete floor. I kind of finished the inside myself still working on that part?? Good luck with your project, also go BIG you will not be sorry I wish I had gone bigger with mine.The Oaks Sign 001.jpg
/ Work shop #11
I went metal and built a 100'x 125' and it cost 45K back in the 90's. I went extra skylights to limit lights, fully insulated with roof vents. Gets up over 120 degrees her and it's comfortable with a cooler. No telling what the wood one would of cost but I do know metal building don't burn up and it saved me a tom on insurance costs.
/ Work shop #13
Any of you tractor types have leads on small barn DYI kits. Something about 20'x40'.
/ Work shop #14
Where are you located?
It helps to have that info in your profile.
/ Work shop #16
There are several local lumber yards here in Oklahoma, that have DIY kits.
Hope you can find some there.
/ Work shop #18
I have a 25 x 40 quonset hut type with straight sidewalls, US Steel. put it up myself. like the design and at the time it was a good buy. Secret-- get the salesman to come out, spend 2-3 hrs talking, they will often deal with "returns, unclaimed, ect" Really helps if his cell phone won't work and he has to use your landline to keep calling his boss. At the time, the original price was $8000+ and he came down to $4000. Just took a little time,:thumbsup:
/ Work shop #19
kennesm
Are YOU still here?
I see you have started this thread have not responed to it.
Like I asked in my FIRST post what type of workshop do you want?
Some thing that is 8x10 feet or a 120 x400 foot building?
What do you plan on working on in it?
If you want some help you have to give us something to go on.
New/Unused Wolverine 72in Quick Attach Smooth Bucket (A65583)
New/Unused...
2016 CATERPILLAR 926M WHEEL LOADER (A65053)
2016 CATERPILLAR...
(2) New 14-17.5 NHS tires on John Deere 6-lug compact tractor rims, Coal Valley, IL (A65640)
(2) New 14-17.5...
84in. Skid Steer Bucket (A65640)
84in. Skid Steer...
Lonestar Panel (4) 24ft. Free Standing Panels (A65640)
Lonestar Panel (4)...
Michelin Mach X BIB 710/70R42 Tires (A65640)
Michelin Mach X...
