Working a field, what is better?
   / Working a field, what is better? #11
Egon said:
Considering all the acres of land that have turned over with a plow inverting the soil should not be a problem.
Yes, and considering the poor condition of farmlands in America today, perhaps all that deep tilling wasn't such a good idea. Topsoil is living material while sub soil is simply dead substrate. When you turn the topsoil under, it dies.
Most farmers know that. Some care. Some don't.
   / Working a field, what is better? #12
98hd said:
Well, thanks for everyone's help. I talked to some local people also and the consensus is to get a disk. Time to start looking again.
Where is "local"? (state? nearest city?)
upper michigan.
   / Working a field, what is better? #14
98hd said:
upper michigan.
Just a tad bit out of range for me. I have a couple different disc's that need to be used a bit to wear some rust off of disc blades. Oh well...
   / Working a field, what is better? #15
I think a disk will give you more flexibility. Using a 1 row turning plow may take a long time on 2-acres. And a disk should get you in the ground a few inches with a pass or 2 and that's all you need for a deer plot. The biggest thing that will help a deer plot is moisture!! :)
Some pics from Saturday when I was doing mine. The disk is a little 5' 3pt.
First pic is my disk setup, with the weight added in sand it'll bury that tractor.
second is some finished disked path, 2 weeks before I ran a sort of homemade 3 shank subsoiler thing. It busted up the black gumbo down to about 4-5 inches. The disk finished the job and cut it up nicely.
3rd, shot of some never touched wooded gumbo. went over it about 4 times and was good enough to catch some seed. I ran a drag over this to cover the seed.
4th..my homemade drag, nice to pull it with an atv.
5th...my seed mix and some rye.
   / Working a field, what is better? #16
Most definetly a plow is not the best impliment in many cases. Cultivators and discs work much better in some situations but usually require a lot more HP to do a proper job. Zero till is probably the best solution but again involes equipment most here do not have and also require larger tractors to pull the seeding train.
As for maintaining the soil the procedures should vary according to the type of soil and nature of the terain plus the quality and quanity of the rain that falls.
But almost universally very deep rooted plants will aireate the soil, bring nutrients to the top and allow water penetration. This would indicate rotation of some kind. If one is depending on the PH of the top 2 inches of soil to raise a crop then he may soon be delusioned. Excessive fertilization is also a big culprit in leaching the soil of it's vital nutrients.
And there are so many other items involved in proper soil maintenance it's impossible for the challenged, like myself, to keep up!:D
   / Working a field, what is better? #17
You've got some decent advice so far. BUT.... What you NEED is good LOCALIZED advice. Someone more familiar with local growing conditions, soil structure, and with knowledge of how to achieve your intended results based on local conditions
Call you "county agent". I'm not familiar with Michigans AG network, but I'm positive there'll be such. County Extention Agents are familiar with what works, based on personal observations and training.
They'll know how deep you want to work the ground, what you need to add to the soil, and what tools work best with your conditions. It's usually free advice, and it's almost always GOOD advice. In my case, they even suggested a state program to improve my pastures without large "out of pocket expense" on my part. (State picked up most of the tab)
Give 'em a call. Nothing to lose and MAYBE much to gain.
   / Working a field, what is better? #18
There is a place for a bottom plow and deep tillage. Often it is desirable to turn lime or fertilizer under. We used to do it regularly when we grew peanuts. We wanted the ph amended down to taproot depth-about 10 inches. Turning the fertilizer under still left it available to the plants, but did not stimulate an early growth of weeds as it would have done if it had been worked into the top four or five inches.
When we prepared land for planting peach trees, we would turn under a couple tons of lime and then add another ton on top of the soil, because that was the last chance for tillage. Also, there isn't a better way that I know of to get a green-manure crop where it will do some good than turning it under with a bottom plow. A winter rye crop turned under in late March is standard procedure for peanut growers in GA.
A much overlooked tillage tool, especially for small farms, is the one-row subsoiler. You can get a field in good shape using only a subsoiler and a disc harrow. I often subsoil on sixty inch centers, then come back with the rear wheels directly over the original subsoiler furrows. The slight slippage of the rear wheels actually loosens the soil (especially clay) and breaks up any clods that were pulled up. This gives subsoil furrows on thirty inches, and a couple of passes with a disk can usually leave a pretty fair seedbed.
Also, subsoiling in the fall allows winter rains to soak in rather than run off.
Of course, as they say, "local conditions may differ."
2011 Ford Crown Victoria Sedan (A51694)
2011 Ford Crown...
Fire Hose W/Holder (A50774)
Fire Hose W/Holder...
2025 20ft. G70 Cargo Transport Chain (A51692)
2025 20ft. G70...
2025 Swict 84in Bucket Skid Steer Attachment (A50322)
2025 Swict 84in...
2019 TOYOTA 8FGCU25 PROPANE FORKLIFT (A52141)
2019 TOYOTA...
4-27x10.5-15 Hauler Skidloader Tires & Rims (A50774)
4-27x10.5-15...
