My
BX25 has lost its "go". This is especially noticeable when in low gear. Let me explain: this was with about 90 hours or so on the machine. I was doing some work for about 2 hours or so moving muck/soil/gravel, using the bucket, from point A to B. That's when I noticed that the speed control pedal (accelerator) became unresponsive. By that I mean when I press the pedal the tractor responds pretty well normally but as I continue to press it the tractor pretty well travels at the same speed. It is very sluggish compared to what it was like. First I thought that the muck was causing the problem or that I got some muck up into the controls. But after checking under the tractor I found no mud and the tractor is acting the same on dry level surfaces. I had the dealer check it out (at the same time I had him install my rear mounted snow blower). I ask the dealer what the problem was and he said that this happens after they are run in for a while. I'm leery about that comment as the performance was totally downgraded from before. My salesman said that the mechanic said that he made a "few adjustments" etc. He also said that this kind of tractor should be run near max rpm. Don't want to go on too much here but, I found that after the problem started I had to increase the engine rpm 400 or more to get any real go out of the tractor compared to what I used before. (For the most part I used to use anywhere from about 2000 to 2400 rpm... not any more!) Anyway got the tractor back from the dealer, complete with snow blower, and when I gave it a test run it was exactly the same as when I gave it to the dealer for repairs. Sorry to be so long on my first post but I am really concerned with my tractor. Would appreciate any/all comments/help.
