CalG
Super Member
- Joined
- Sep 29, 2011
- Messages
- 9,156
- Location
- vermont
- Tractor
- Hurlimann 435, Fordson E27n, Bolens HT-23, Kubota B7200, Kubota B2601
Just a note of "historia" ;-)
the Fordson E27n that I have is a straight gas tractor with magneto ignition. In this same model year (1950) one could have the tractor fitted with petrol fuel, as I have, or TVO (Thermal vaporized oil) in which the engine is started on gasoline, but when warmed up, runs on kerosene, (don't forget to change over before shut down or the carb will be filled with TVO!) or the same tractor fitted with a Perkins four cylinder compression ignition engine that runs diesel fuel.
It would seem that immediately after the Second Great War, fuel availability was more important than fuel type it's self. There were great numbers of these tractors sent to Canada and to Australia in all forms.
Me, I am happy to have the straight gas tractor. The only issue I have, is that in the hills, when the tank runs low, sometimes fuel doesn't cover the tap, and the engine sputters and dies just when it is needed most. (Don't ask what happens to the splash fed front main bearing) In the same way, when the tank is full, an uphill run will have gasoline gysering out of the filler cap vent and right into my lap!. Oh well, It only burns for a few hours.... ;-)
