WR long Valve install?
/ WR long Valve install? #1
MrZukerman
Bronze Member
Northern Ark.
Kubota L3410
I have searched and searched but can't find the exacted answer I'm needing on this. I'm looking at a WR long third function valve for my L3110.
How many lines hook up to the block on the valve? The best I can find is a pressure in and a pressure out, and two work ports for the cylinder is this correct? Everything I've been running across when adding a third valve is you have to have a tank return to go along with the power in and out on the valve how does this valve work with out it? I was planning on running my power beyond line from my loader valve to the new valve and then back to the tractor. Thanks Billy
/ WR long Valve install? #2
The electric-over-hydraulic valve only uses for hoses total. IN, OUT and the two work ports.
UNUSED FUTURE EQUIPMENT SEAT (A60432)
UNUSED FUTURE...
CATERPILLAR SSL PR118M HYD POWER RAKE (A60429)
CATERPILLAR SSL...
2014 Freightliner Bucket Truck (A56438)
2014 Freightliner...
Kubota LA525 Front Loader Tractor Arm Attachment (A59228)
Kubota LA525 Front...
1761 (A58375)
1761 (A58375)
2014 Ram 1500 4x4 Crew Cab Pickup Truck (A59230)
2014 Ram 1500 4x4...
