X 300 stalls after 10 minutes
   / X 300 stalls after 10 minutes
Pulled off the tin and recoil plastic shield. Lots of dust but no nest or grass. I don't believe this amount of debris could cause the problem. I am going to push it hard again today with the cowl off. If nothing happens Ill put it back on and see what that brings. Couple more questions. While I am cutting and trying to watch the hour meter as close as I can what does it read if it stalls out? At the same time I am watching the spark plug testers glow orange and not smash into something! Here is my thought process jump in and correct me when I go astray. Lets say it stalls and I am fast enough to see plugs still firing but stalls anyway. Wont restart immediately. If the plugs are firing but not starting has to be a fuel issue. If it wont immediately start but no plugs firing I am back to an electrical problem.
   / X 300 stalls after 10 minutes #22
What does the oil look like? On some small engines, if the oil is dirty, they wont run. Is the exhaust clear? I had a dirt dobber partially plug up my generator exhaust and it drove me crazy trying to figure that out.
oil looks good, I changed it the beginning of the season and it doesn't get used that much. Looks clean no gas smell. Ill check the exhaust today thanks for that. I ran it quite a while yesterday pushed it hard and still didn't stall out. Ill put the cowl back on today and do more testing.
All seems well now. I did blow back from the fuel filter into the tank just following one of the previous suggestions. Mowed for about 35 minutes with cowl on seems to be ok. Ill keep my fingers crossed and thanks for all the help!!!!
   / X 300 stalls after 10 minutes #25
I had breaker that was stopping my John Deere, and after I waited for awhile it would start back up. Took me a while to find the problem, because I didn't use the tractor much.
2008 Ford F-350 Service Truck (A53422)
2008 Ford F-350...
2013 MACK CHU613 DAYCAB (A55745)
2013 MACK CHU613...
1999 GMC C7500 Mason Dump Truck (A55852)
1999 GMC C7500...
Polaris Side by Side (A50324)
Polaris Side by...
2011 Chevrolet Uplander Van (A51694)
2011 Chevrolet...
2007 Volvo VNL Truck Tractor (A55315)
2007 Volvo VNL...
