Yamezz;2188083 Would thicker oil have put more strain on the transmission?[/QUOTE said:Thicker oil would only effect the hydro function it would not put extra pressure on that part of the case.
I suspect the age has little to do with it. I have a new X749 which is similar in durability, could have bought the X748 with a loader option but didn't think it was heavy enough. I think heavy work will tear any of these mowers up in short order, best to use them for light duty tasks.
Is it possible to bend the hubs or axles on these? My X475 has a horrible wobble when you drive it on dry pavement. It moves up and down in the rear. I thought it was bent wheels, so I replaced the wheels and tires, and it still down it.
I have tried to put a stick on the hubs as they spin, and they seem perfectly straight, yet it still wobbles when you drive it.
Is it possible the wheels are that bad right from JD? I bought the 26 12 12's that have the gator tires on them. they bite good in snow, and are easy on lawn.[/QUOT
Does it do it at all speeds or just at higher speeds? Try letting out some of the air in the tires, too much can cause bouncing. Let us know if this works.
