X700 series mower deck interchange
/ X700 series mower deck interchange #1
KennedyDiesel
Veteran Member
Central WI
There has been a lot of speculation as to whether the decks for the new 2013 x7's will fit the prior models or not. It is reasonable to assume that they will since the wheelbase has not changed, but it would sure be nice to know for sure. Mounting attach points could mess with the swapping would be my concern.
Also worth noting that just because they are styled like the 7 iron does not mean that they are dimensionally exact.
To me, the 9 ga should still be plenty tough. I mean the deck on my 96 era 455 is still plenty solid condition, it just does not cut to my satisfaction due to volume design.
/ X700 series mower deck interchange #2
From what i'm seeing, the new decks are high capacity decks, with a deeper profile. they have increased
room under the tractor to accomodate the new decks. It looks like old decks will come forward, but new decks
may not fit old style tractors due to clearance underneath, although it doesn't say for sure yet.
From our sales info:
Equipment compatibility
Most equipment and attachments used on X700 Ultimate Tractors may also be used on X700 Signature Series, with the following exceptions:
The 45 Loader is not compatible and is discontinued. No loader is available for Signature Series.
An upstop kit, BM24370, is required to install the 48X Mower Deck or prior year 54X, 62X, or 60-in. 7-Iron™ Mower Decks.
A new hard cab and weather enclosure is required for Signature Series Tractors. The soft cab is discontinued and is not available for the Signature Series.
A new front brush guard, BM24375, is required for Signature Series Tractors.
New front fender kits are required for Signature Series Tractors.
BM24429 front fender kit for X710, X730, and X750
BM24430 front fender kit for X738, X739, and X758
BM24425 auxiliary alternator kit is required for X710, X730, X734, X738, and X739.
BM24363 9-weight front weight bracket is required for Signature Series Tractors.
/ X700 series mower deck interchange #3
An upstop kit, BM24370, is required to install the 48X Mower Deck or prior year 54X, 62X, or 60-in. 7-Iron Mower Decks.
It is no deeper of a profile than the current 60 inch 7 Iron deck. Why would they increase room under the tractor, when the 7 iron deck already fits 2008 to 2012 models? That right there negates any purpose for changing the underside of the machine itself. I am not saying John Deere didn't change anything, but since we know the 7 Iron already fits, and it's bigger than any other deck out there, why would you change what works?
This is just a guess, but I am assuming JD moved the rear axle back on the frame, and the front axle forward on the frame. This would give the illusion of more space under the machine, even though the wheelbase is the same as the previous generation.
What I am particularly curious about is why JD needs new front fender kits. This obviously means they changed the axle design for both the 2WD and 4WD models. Or, maybe it is just because of the new decks. I would be shocked if JD changed the axle setup on these machines, it's been nothing but reliable since day 1.
I did talk to a dealer today who was part of the design/feedback team and was told that the new frame is actually heavier.
I hope to get to see one in person soon.
FWIW moving the axles would change the wheelbase.
/ X700 series mower deck interchange #5
My bad, what I meant was the overall length of the machine.
I will be surprised if the frame is heavier, given JD has very strict requirements they have to meet in order to avoid putting a ROPS on in 2014. The requirements are such that the only choice was to lose some weight, not gain any.
So much conflicting information it is maddening! I can't wait until someone buys one and puts up photos. I live in Canada and we get everything later, so we won't see any 2013's for another 6 to 8 weeks yet.
/ X700 series mower deck interchange #6
Keep in mind that the 7 iron deck is incompatible with AWS. These new decks all work with AWS. AWS has a lower ground clearance. This too could be a factor. AWS, the deep deck with drive over feature are probably what necessitate the spreading of the wheels. While I haven't driven one, I like the idea of the front wheels out in front of the tractor (I think).
/ X700 series mower deck interchange #7
The front wheels are already far out front on the 2008 to 2012 models, I can't imagine them being any further forward.
/ X700 series mower deck interchange #8
This just keeps getting more confusing. My dealer confirmed to me that the new 700 series is about 100 lbs lighter. But having said that there are other things that don't seem to add up.
Eg.
1) Some folks have suggesated that the frame is thicker on the new models (even Deere references at least an area that is thicker) so the new 700 frame should be heavier
2) The motor is bigger (that is a fact) so that should add some weight to the new 700. When we went from the 1.1 to the .9 wasn't there a loss of weight of about 65lbs?
3) The transmission is the same
So from this we see that with the new 700, two of the three heaviest components contribute more weight than its predeccessor and yet it is supposed to be 100lbs lighter.
Anybody else confused?
With a heavier frame and potentially more welding than bolts less fasteners are needs and less supporting structure is needed. Displacement of the engine does not necessarily affect weight depending on if the engine family changes or not. Of the engine is same and a larger bore is used then you trade cast iron for aluminum.
Can anybody confirm with absolute certainty that the 60" 7 iron deck will fit the new models at least with 2ws?
I'm thinking I'll put Ma/Brother into a 740 7 iron (WAY overkill) and I'll have a look at the 750 and consider it. It would sure be nice to see what these "all new models" really did different. My dealer says he has one but no deck on it yet. I hope to get by to have a look, but he's 40 miles away.
/ X700 series mower deck interchange #10
Maybe but John Deere's literature states that the old model had a "fully welded frame".
WRT to the 60" 7iron, Deeres literature says that it will work with a kit.
Do you know this to be a fact? Until we see the decks side by side we won't know. The reality is the new HC decks could well be an improvement over the 7 iron with even more volume or a profile change therefore creating clearance issues that don't allow them to fit prior models which seems to be the case.
/ X700 series mower deck interchange #12
yupper, at least according to our internal sales info, from my post above highlighting 2013 changes:
/ X700 series mower deck interchange #13
Why would John Deere release a deck better than the 7-Iron, and charge less for it? They would never do this.
There is no way the new decks are BETTER than the commercial grade 7 Iron. The 7-Iron deck makes John Deere a lot of money, and they aren't going to charge $1,500 for a new HC deck if it is better than the $2,500 7 Iron. If the new deck was better than the 7 Iron, it would be equal to or greater than the cost of a 7-Iron deck. Anything else means JD loses profit, and we all know they won't let that happen.
My stance is the new deck is the same shell design as the 7-Iron, in a thinner gauge metal, with drive over ramps, nothing more. I can't see the new HC decks having more volume than the 7-iron, because as I said before, JD would be shooting themselves in the foot.
/ X700 series mower deck interchange #14
You are right in that we won't know until someone actually sees one of he new decks. However, if I was a betting man I would be siding with JDTank on this one. Better than the 7iron? Hard to imagine.
/ X700 series mower deck interchange #15
Prices per John Deere web-site:
60 In. 7-Iron Shaft Driven Mower Deck for X700s (60D) SKU23646 $2,200.00
60HC Mower Deck X700 for Signature Series (Model Year 2013 and Later) 9075M $2,100.00
Also note the new 60HC Deck for Model Year 2013 and Later.
/ X700 series mower deck interchange #16
I think the new decks is a strategy to increase X700 series sales.
These machines are premium machines, so every deck available for this series should be a high end premium deck design as well.
I have no doubt the HC decks will be better than the previous generation decks, but it's all so much speculation right now.
Someone hurry up and buy one so we can see!
With the price that close I'd say that there is a good possibility that there is an improvement but you never know. The 7 iron deck is great and it would make sense to clone it in a lighter material, but why stop there? Surely it was not perfect...
I'll have to go back and view my quotes, but from what I saw the 740-7I was almost $2000 less than the 750-60HC . The 750 is $500 more list and there is $1000 program so that's $1500 of it but I'll have to ask the dealer where the extra $500 comes from.
/ X700 series mower deck interchange #18
If or why they might have moved the wheels is pure speculation on my part, and not really the point. The point is that the 7 iron on older models won't work with AWS. So, in a pre-2013 tractor if someone wanted AWS they had to settle for the inferior mower deck (relatively). This is what has kept me from pulling the trigger. Now, these new decks, while maybe not the deck that the 7 iron is, look to be a big improvement over the standard decks of prior years. What's disappointed (but not a total deal breaker) is they have now taken away diesel AWS/AWD models. I don't know why they wouldn't support that configuration, at least on a special order basis given all the parts are there.
/ X700 series mower deck interchange #19
Perhaps some or all of the extra $500 is for autoconnect?
/ X700 series mower deck interchange #20
It could be because of weight issues. The diesel engine package is heavier than the gas package, and the AWS rear transaxle is heavier than the standard rear transaxle. Maybe the combination of these together put them over the ROPS weight threshold.
I don't think so. Autoconnect is about a $300 option on all X700 Signature Series tractors (it is not standard on any of them so isn't included in Deere's MSRP prices).
78in. Hydraulic Root Rake Grapple Skid Steer Attachment (A59228)
78in. Hydraulic...
iDrive TDS-2010H ProJack M2 Electric Trailer Dolly (A59230)
iDrive TDS-2010H...
2015 Peterbilt 389 T/A Wet Kit Day Cab Truck Tractor (A55973)
2015 Peterbilt 389...
2004 GMC Sierra 3500 Pickup Truck (A55973)
2004 GMC Sierra...
2018 LARK UNITED MANUFACTURING S/A GUARD SHACK (A55745)
2018 LARK UNITED...
2017 CAT 315F LCR EXCAVATOR (A58214)
2017 CAT 315F LCR...
