X738 Constantly Blows Fuses
/ X738 Constantly Blows Fuses #1
OutBurst
Connecticut
John Deere 1026r
My new-to-me 2013 X738 won't run (or start) because it keeps blowing the 20 amp fuses. Is this a common problem with a simple solution?
/ X738 Constantly Blows Fuses #2
Wouldn't think it is a common problem.
Rig up a light bulb to plug into the fuse slot.. if the bulb lights then it shows a short. Track down what is causing this circuit to short out.. maybe a chewed wire grounding out somewhere. Moving wiring around may cause the light to go out, thus finding the culprit.
/ X738 Constantly Blows Fuses #3
I agree a light instead of fuse is the way to trouble shoot a short.
Does the fuse blow with the key at RUN? Or only when advanced to START? That might help point you in the direction of the short.
SOLVED! There was a frayed wire under the gauge cluster. I taped it up well and it is good to go!
/ X738 Constantly Blows Fuses #6
Most likely a chaffed (shorted) wire somewhere. That's what fuses are for, to keep your tractor from catching fire and burning down.
2013 Chevrolet Silverado 1500 Ext. Cab Pickup Truck (A59230)
2013 Chevrolet...
2017 PETERBILT PB337 HYDRA-TAIL FLATBED TRUCK (A59823)
2017 PETERBILT...
(1) 30"X7' ADS DRAIN PIPE (A60432)
(1) 30"X7' ADS...
2015 Nissan Altima SV Sedan (A59231)
2015 Nissan Altima...
DIRT DOG AGR72 GRAPPLE (A60430)
DIRT DOG AGR72...
JOHN DEERE 772GP MOTOR GRADER (A58214)
JOHN DEERE 772GP...
