x748 or x749 - 7-iron or AWS
   / x748 or x749 - 7-iron or AWS #51
LB, I am not sure I follow you on the tractor comparison. Really what seems is happening is giving our OP some other options. As for my opinion on the 2320, I rarely use high gear except for transport. I use low for ground engagement and mowing. I am not sure of the speed, but at WOT it is similarly fast to an X series when mowing. No utility tractor, no matter what the size, will be as manuverable as a dedicated garden tractor, and the 2320 is no exception. It is quite manuverable with much greater capability and for not a huge amount more money. Just a thought for option. I will say the 2305 is also an option, but when I tested one on my property I found the 2320 to be a lot stouter machine and it felt as though it had more power. If mowing is the primary duty then going with the 2305 in the JD line might be a better option. It is not as quick and comfortable and manuverable as the X series but does better with a loader, etc. if that is ever needed. I recommend any time one has a utility machine, loading the tires is a given, either with liquid ballast or wheel weights or both. As for the X 748 and tearing up the grass, my X 595 (identical machine--different number) never damaged my lawn in MFWD.
John M
   / x748 or x749 - 7-iron or AWS #52
I think the 2520 has bigger tires that would raise this, and since 95% i'd be just mowing anyway, i'm sure the 2320 power is sufficient.
Since you say 95% of the time your just mowing , IMO you should focus on
the X748 or X749 , even maybe the older series X4xx / X5xx , ask ccsial how
nice the SE seat is ...
Later,x595
   / x748 or x749 - 7-iron or AWS #53
I can vouch for the seat. I wouldn't part with it.
   / x748 or x749 - 7-iron or AWS #54
I've had a 495 and loved it but traded for a 3520 took on more grass and landscape work. If I were you with hillsides I'd go with the diesel w 4wd with the widest 7 iron deck available 62" . They are lower (center of gravity) than the subcompacts and cut great. jmho Hoddykubody
More info coming soon! (A53421)
More info coming...
2005 Tennant ATLV 4300 Turf Vacuum (A55851)
2005 Tennant ATLV...
Adams 6T Fertilizer Spreader (A55301)
Adams 6T...
1999 INTERNATIONAL F-4900 TANK TRUCK (A56129)
1999 INTERNATIONAL...
flooring (A55758)
flooring (A55758)
2016 Tesla Model S 85D Long Range AWD Sedan (A51694)
2016 Tesla Model S...
