Yanmar 150d workshop manual/ loader manual
   / Yanmar 150d workshop manual/ loader manual #11
I suspect some of your images won't load because they exceed the size (in kb) that TBN allows. Try re-sizing the failed ones.
   / Yanmar 150d workshop manual/ loader manual #12
I was thinking the same thing, the last lot are very hard to see when they are that big.
   / Yanmar 150d workshop manual/ loader manual #13
Throttle indicates a grey market tractor. I'm guessing 1300D. The hood decal sure looks like it belongs though. Also thinking it is unusual to see a Yanmar loader on a grey market tractor? :confused: Or maybe that is not a Yanmar loader, going by color looks like it might be.
   / Yanmar 150d workshop manual/ loader manual #14
I agree, It could be off a 155D hence the colour? A 155 crossed with a 1300 makes a 150 No?
Checked serial number that is actually stamped on the side of trans housing and it reads TM 13000 03347. so guess it is a YM1300D for sure. Throttle shut off lever is push forward to shut of fuel. Hood is from who knows where. Does this make sense to you folks? Soon as I can get pics to post better will get them on. Engine type is 2TR13 as was previously suggested. Marking is a edge of top rad hose where hose enters top of cylinder head. Thx for your patience. Boltz
   / Yanmar 150d workshop manual/ loader manual #16
Agree. It looks like somebody started with a Japan-market YM1300D and sourced replacement parts from a US salvage yard. Hood for sure. Loader is very likely the US dealer option loader, made in US, a loader never sold in Japan. Is its fluid reservoir in the right column? I'm not familiar with that.
I think that air cleaner was unique to US models and never used on YM1300. Its a 'Donaldson' type, unneeded for dust-free rice paddy work but better filtration and preferable for operating in dust.
I don't know if that seat is unique to US models but don't get rid of it, it is larger and therefor easier to get on/off the tractor compared to the common US aftermarket replacement seat that crowds you up against the steering wheel on these tiny tractors.
Anybody - does that governor assembly look right for that model? Its unfamiliar to me.
   / Yanmar 150d workshop manual/ loader manual #17
I'm guessing there was a YM150D created for some markets, (European?). Would not be the first time we have seen this. Although the throttle does appear to be forward in, assumedly, the off position, which Yanmars have exterior air filters? the YM155 does, the YM1300, YM1401, YM1500 do not.
Throttle forward is shut off for sure. Metal seat was all split open and full of holes, and had no cushion on it when I got it, so spent a hour and straightened it and brazed up holes and cracks. Seat matches my pictures in YM155D parts manual exactly and has two vertical rubber cylinders for seat to rest on but nothing is there that cylinders could contact to provide support , (still trying to figure that out.) Loader hydraulics fill in right hand upright and use it for reservoir. I got two identical parts manuals in English that say YM155 (D) on front cover. Parts on my tractor are matching those so far that I have compared except for air filter as you suggest. My manual shows paper element in round housing mounted on side of intake. No part number on manual except on rear cover right bottom YP7603-05 if that means anything. Tractor also had back hoe on it, hoe was sold to someone else before I got it, but hydraulic pump is still on pto. Boltz (PS still working on more pics)
   / Yanmar 150d workshop manual/ loader manual #20
With some apps, (AOL), you can zoom the pics down to 10% of original. Works perfectly in this case.
Harley Davidson (A56859)
Harley Davidson...
(4) ALUMINUM RIMS FOR KAWASAKI MULE (A58374)
(4) ALUMINUM RIMS...
2019 John Deere 1025R 24HP 4WD Loader Utility Tractor (A55973)
2019 John Deere...
HYD QUICK ATTACH STUMP GRINDER (A52706)
HYD QUICK ATTACH...
FORD 3PT. REVERSABLE SCOOP PAN (A52708)
FORD 3PT...
2025 GPS 11.5ft Utility Trailer (A56859)
2025 GPS 11.5ft...
