Yanmar 2000 BD 4x4. Need to replace ft seal
   / Yanmar 2000 BD 4x4. Need to replace ft seal #1
Tim_Ternest
OK GUYS NEW AT THIS. I NOTICED THAT I HAVE FLUID RUNNING DOWN ON THE FT INSIDE WHEEL.LOOKS LIKE IT IS COMING OUT FROM THE MOST OUTER SEAL NEXT TO THE WHEEL. CAN SOMEONE HELP WITH TEAR DOWN. AND ALSO IS THERE AN ONLINE SERVICE MANUEL TO REFER TO.......THANKS TIM
   / Yanmar 2000 BD 4x4. Need to replace ft seal #2
Tim,
Just above your post at the top of the thread is Hoye Tractor. If you follow the parts list and click on YM2000/YM2000D ONLINE, Aaron provides an excellent parts break down that will show you what's involved in disassembly of the front knuckles on the FWD. The "cllick on numbers" also give you the part name and price.
Their manuals, parts and prices are good, and knowledge of Yanmar and willingness to help are even better.
Welcome to TBN.
Mark
I went to Hoye tractor and on my 2000bBD there is not an online section on the ft axle or diagram. But thanks ....tim
   / Yanmar 2000 BD 4x4. Need to replace ft seal #4
You should replace the large hub gear while you have it torn down.
   / Yanmar 2000 BD 4x4. Need to replace ft seal #5
Sorry, I stand corrected...it's not online.
thank you... Is that gear one that wears out often?
   / Yanmar 2000 BD 4x4. Need to replace ft seal #7
I meant to refer to the seal and not the gear! Sorry. The large seal is notorious for leaking and is not expensive.
bruce
2009 Kubota RTV1140 (A57148)
2009 Kubota...
2013 Ditch Witch XT855 Tracked Loader (A56438)
2013 Ditch Witch...
2013 Ford F-250 4x4 Ext. Cab Pickup Truck (A60460)
2013 Ford F-250...
Mini John Deere Truck (A55853)
Mini John Deere...
2013 John Deere 824K Wheel Loader (A56438)
2013 John Deere...
404 (A52706)
404 (A52706)
