Yanmar 2000 BD 4X4 Steering is getting stiff
   / Yanmar 2000 BD 4X4 Steering is getting stiff #1
Tim_Ternest
<font color="blue"> </font> /forums/images/graemlins/laugh.gif I have noticing that my steering is getting alittle tight. I removed the linkage from the side and checked just the steering box. It seem to be the where stiffness is coming from. What can I do . I didnt see any grease fitting, Any ideals I did see some type of screw on the right side of the steering box.
Now i see that 90w fluid should be in the gear box. How ,and where do i add AND CHECK FLUID? I removed the pittman arm from the long linkage bar and turn the steering wheel it seem stiff and you can hear squaking when you turn it. HELP Please
   / Yanmar 2000 BD 4X4 Steering is getting stiff #3
Tim,
The manuals don't give much info on steering, except instructions on how to tighten.. dosen't sound like that is your problem. I haven't added any fluid to the gearbox on my 2000B yet, but I suspect it is through that little plug in the front of the box, you know, the one you can't get to. Check out the Steering Shaft Fix article on Hoye's site. If you want, you can PM me and I will send some scans of the service manual for the YM2000 steering.
Bruce
Thanks Bruce, This morning I am to look closer at the steering box to see about checking it out.If I did check out Hoyes section on steering if you have a better break down on the steering that would probally help. Thanks
Tim
Ok , I now removed the gas tank and got to the allen screw where you can add fluid. I saw what appears to be grease. I probed the box with a small screwdriver. seem to possible have air pocket or dry area. so i added 80-90wt fluid now I can see the fluid move as i move the wheel back and forth. but still seems tight. I have the tractos ft wheels off the ground. and can still hear a small squeak when i turn the wheel. it is smooth and i can turn with one hand but seem tight. NOW WHAT Help Tim
   / Yanmar 2000 BD 4X4 Steering is getting stiff #6
Either keep working it and hope it will free-up, or take it apart and see what the problem is.
   / Yanmar 2000 BD 4X4 Steering is getting stiff #7
You may have bad bearings or the steering shaft may be rusty. If it doesn't improve, you should tear the steering box apart & fix it before more damage is done.
2017 Ford Explorer AWD SUV (A51694)
2017 Ford Explorer...
(4) 250/80-15 Solid Forklift Tires (A52384)
(4) 250/80-15...
REIST R25PSS LOT IDENTIFIER 59 (A53084)
REIST R25PSS LOT...
(2) METAL SPOOLS W/ SOME DURALINE 4" PVC PIPE (A51248)
(2) METAL SPOOLS...
JOHN DEERE 8R 280 (A53084)
JOHN DEERE 8R 280...
2005 IH 7600 t/a Dump Truck (A52384)
2005 IH 7600 t/a...
