Yanmar 2210 BD capable of pulling small baler? Like 315 new holland?
   / Yanmar 2210 BD capable of pulling small baler? Like 315 new holland? #11
OK, found some details.
The New Holland older series like the Super Hayliner 68 can be driven by 17Hp PTO. It does 70-stokes/min. It's very popular with the Ford N (9N-2N-8N-NAA) series tractors. Here is a link to a few of the balers these can use. Likewise those should work for you too.
NTC Manual Library
Also, some of the square balers out there have an independent small diesel engine on them, thus if your tractor isn't robust enough to run the baler via the PTO, then the baler's own engine can. Of course, these balers cost a bit more.
   / Yanmar 2210 BD capable of pulling small baler? Like 315 new holland? #12
NTC Manual Library
   / Yanmar 2210 BD capable of pulling small baler? Like 315 new holland? #13
I could be wrong but all the New Holland balers I've baled with have an over running clutch in the flywheel area. There is no need to buy a separate one.
You're correct. The ORC has to be on the baler to protect the pto shaft and the tractor transmission while the baler flywheel is spinning down. The slip clutch is needed in case something jams in the baler (the pickup, the packer, and/or the plunger). If you're buying an old baler, it's smart to rebuild and readjust the slip clutch and to check the ORC to be sure it's not busted or worn out.
   / Yanmar 2210 BD capable of pulling small baler? Like 315 new holland? #14
You don't need a slip clutch on the old balers... They are "shear pin" protected! If the baler jams, the pin shears...
At least that's the way every old NH baler I've owned or ran worked!
SR
TRAILMATA DESOTO CLASIC TRI-CYCLE (A58374)
TRAILMATA DESOTO...
2014 VOLVO VHD DAYCAB (A58214)
2014 VOLVO VHD...
25 TANDEM DUAL GOOSENECK TRAILER (A55745)
25 TANDEM DUAL...
Magnum 4000 Series Hot Water Pressure Washer (A55272)
Magnum 4000 Series...
DEUTZ MARATHON...
FORD F SERIES DUMP TRUCK (A52707)
FORD F SERIES DUMP...
