Yanmar 2310d won't move
   / Yanmar 2310d won't move
There was not a gasket on a one of them.
   / Yanmar 2310d won't move #82
I don't have a 2310 parts manual but according to the 276 and 2210 manual there should be gaskets on the ones mentioned.
You misunderstood Winston...I'm saying that the ones I mentioned did not have a conventional gasket on them when I took it off, they had the "gasket sealent in a tube" type on there. I'm just wondering on the ones that do require the use of a gasket, is there a difference in using an actual replacement gasket from a parts store, as opposed to buying a big tube of permatex and doing all of them for $5 - $10.
And there was nothing on the drop box but the o-ring, but there isn't anything listed in the manual either so I guess an o-ring is fine.
Sorry to be confusing...
   / Yanmar 2310d won't move #84
I'm slow to catch on. I understood you, just saying I would buy the gaskets if it were mine or buy material and cut them. Sealant will probably hold fine, just seems right to put it back like designed.
And I agree. I just don't know enough about it and thought if there was no difference I would use the goop stuff. I'll order the ones I can get.
All parts including gaskets ordered from Hoye this morning.
Parts have shipped. I believe everything I need to put this baby back together are scheduled to be here tomorrow. Can't wait to see if I can get it done. :)
   / Yanmar 2310d won't move #88
Good news. Best of luck. I'll be watching and rooting for you. :thumbsup:
   / Yanmar 2310d won't move #90
Now hopefully the correct gaskets and parts are one the way. Since you was the one that took it apart and found the problems then putting it back together with the correct parts is usually the easiest thing to do. I hope it doesn't become a roll of the dice and you just get lucky getting everything you need.
2014 Volkswagen Jetta Sedan (A50324)
2014 Volkswagen...
UNUSED FUTURE QUICK ATTACH CURVED LOG GRABBER (A51244)
UNUSED FUTURE...
AGT Agrotk 680 Drop Hammer Attachment (A47384)
AGT Agrotk 680...
Kuhns AE10 Small Square Bale Accumulator - 10-Bale Efficient Handling System (A52128)
Kuhns AE10 Small...
2015 Ford Focus SE Sedan (A50324)
2015 Ford Focus SE...
UNUSED JCT SKID STEER QUICK ATTACH HAYSPEAR (A51244)
UNUSED JCT SKID...
