Yanmar Engine Seal replacement
   / Yanmar Engine Seal replacement #1
cef2lion
Central PA
JD 4410, JD455
I have a JD322 L&G that I'm changing the rear engine seal. It has a Yanmar engine. I have the old seal out and have two questions on installing the new seal.
The seal is encased in rubber.
I was wondering if I should put any gasket sealer around it where it presses in? Didn't appear to have any on the old one.
Also, what might be the best thing to use in pressing it back in? Since the seal has a rubber coating I don't want to damage it while installing it.
Craig
   / Yanmar Engine Seal replacement #2
You shouldn't need any sealer, I usually just put a lite film of clean oil on the seal and press it in.
I use a socket slightly slmaller than the outer diameter of the seal to drive it in. Make sure it goes in evenly. You can use a dead blow hammer if you don't want to ding up your socket. You can also use a section of pipe cut square and de burred.
Kuhn Knight 8124 Slinger Manure Spreader (A59814)
Kuhn Knight 8124...
500 Gallon Fuel Tank with Pump (A55853)
500 Gallon Fuel...
PALLET OF SCRUBBER PODS (A58214)
PALLET OF SCRUBBER...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
John Deere 2640 2WD Tractor with 146 Front Loader (A57024)
John Deere 2640...
KUBOTA SVL97-2 SKID STEER (A60429)
KUBOTA SVL97-2...
