YANMAR front right hub/ wheel wont turn? 2210BD. Looking for some advise?
   / YANMAR front right hub/ wheel wont turn? 2210BD. Looking for some advise? #11
By toboggan he means back up while sliding the front along on the bucket
   / YANMAR front right hub/ wheel wont turn? 2210BD. Looking for some advise? #12
Duplicate
By toboggan he means slide on the front bucket
Thanks Tom, Im a total novice. Just retired, now living off of a pension and wishing I could work overtime to pay for this kind of stuff. I guess Im going to learn how to try and fix this. I sent some questions to Hoye tractor too. Once in the shop I will at least have it out of the weather come winter. Thanks again.
Dave
   / YANMAR front right hub/ wheel wont turn? 2210BD. Looking for some advise? #14
I think Hoye can find all the parts you need but it might take a while to round them up.
Your parts manual should be a sufficient guide for how to dis-assemble the hub. I assume the part numbers in the manual are legible. Don't worry about the names for the parts, just reference page/part number when talking to Hoye.
These Yanmars are simple enough for an owner to maintain.
California, as much as I hate to admit it, which one is the 4x4 disengage? when I bought it, coldwater old me to just eave it in 4x4.
Dave
   / YANMAR front right hub/ wheel wont turn? 2210BD. Looking for some advise? #16
Oops - gotta run to pick up my kid at SF airport.
Yanmar's 4wd shift lever usually sticks out of the left side of the transmission, but I'm not sure on that model.
Is there a parts diagram for that transmission on Hoye's website?
   / YANMAR front right hub/ wheel wont turn? 2210BD. Looking for some advise? #17
Looks like it had some water in there too...
   / YANMAR front right hub/ wheel wont turn? 2210BD. Looking for some advise? #18
Your 4 wheel drive shift lever is on the left side. If you look on figure 48 in your parts manual you will see it. Those are drain plugs on the botton of the knuckle housing. See figure 28 reference 11.
Probably are tight, but just check bolts 26 and 27 on figure 28 for tightness. These are the bolts that hold the two knuckle housing together.
Here is a picture sort of showing the tobboggan manuver. http://www.tractorbynet.com/forums/...4-yanmar-2010d-4x-w-fel-yanmar-left-side1-jpg
Sent you a pm.
Sent you a pm.
Winston the numbers you are giving me are not jiving with the on line manual I have to try and match them up. I think I know which one is the 4x4 lever as its really the only one left. is push in or out engaged?
RUMBLON
   / YANMAR front right hub/ wheel wont turn? 2210BD. Looking for some advise? #20
Winston the numbers you are giving me are not jiving with the on line manual I have to try and match them up. I think I know which one is the 4x4 lever as its really the only one left. is push in or out engaged? RUMBLON
On my 2020 the lever when moved forward is in 4wd. And back is not in 4wd
2017 Bobcat T595 (A55272)
2017 Bobcat T595...
2023 BigTex 10SR-12XL T/A Dump Trailer (A56858)
2023 BigTex...
PNEUMATIC GREASE UNIT (A58216)
PNEUMATIC GREASE...
CFG Industry H12R Mini Excavator (A57149)
CFG Industry H12R...
2012 LEDWELL 48FT DOVETAIL TRAILER (A58214)
2012 LEDWELL 48FT...
2014 CAT CT 660 Tandem Axle Dump Truck (A59213)
2014 CAT CT 660...
