tallyho8
Elite Member
- Joined
- Aug 1, 2004
- Messages
- 4,543
- Tractor
- Kubota L4400, Kubota ZD326
jimmer2880 said:I know that this is WAY off in left field. But.....
Some yanmars, run their regurn fuel into a collection bowl (for cold starting), then back into the tank. What would happen if that return line was somehow partially clogged? On startup, the line would have no pressure, but after running for a bit, it would fill up and there wouldn't be any room for the return to go. But, if that was the case, I guess there would be lots of black smoke from unburned fuel. On second thought, nevermind - wasn't a good idea after all.
This has been mentioned and in post #19 I took off the return lines and no fuel came out. I was wondering if much fuel was supposed to come out while the engine was running.
I really thank all of you for the suggestions as I am now clueless as to what my next step will be. I guess I need to remove the injectors and find a place to test them. But since they work perfect when cold I don't know if defective cold injectors will test bad.
