Yanmar NS10 Hopper Cooled Diesel
/ Yanmar NS10 Hopper Cooled Diesel #1
90cummins
Florida Ma.
Ford 1720 SSS 4x4 Turbo Charged
Is anyone here familiar with Hopper Cooled Yanmar diesel engines with the huge exposed flywheel that is started with hand crank?
It is similar to those antique gasoline hit & miss engines often seen at county fairs with steam escaping from the open top water reservoir.
A google search identified it as possibly a Yanmar NS10 10hp diesel.
A search of the Yanmar website does not list it but a google AI search shows many photos of units for sale.
Thanks 90cummins
/ Yanmar NS10 Hopper Cooled Diesel #3
Thanks 90cummins
Records show this is an Ag engine as TS120/NS10 with an 88 sized piston.
The newer TS model is the TS190
/ Yanmar NS10 Hopper Cooled Diesel #4
Upon inspecting your image, it does look to be a TS-xxx model.
Finding info on the historic TS-120/NS-10 is challenging as it was made way back in the 1970s.
I forgot to mention the numbers 00141E stamped on the block.
90cummins
/ Yanmar NS10 Hopper Cooled Diesel #10
Thanks 90cummins
Back to your image and these from Yanmar, even the platform looks the same.
/ Yanmar NS10 Hopper Cooled Diesel #12
Seeing the color yellow, I would assume this model was a road-crew genset for hwy maintenance or construction at one time.
Yanmar and Kukje have been partners for 60+ years. Kukje makes many of the Yanmar parts.
Here is the Kukje KD-120
I have run the engine loaded (2200 rpm) approx 3kw to warm it up and changed the oil @ cleaned oil filter several times. Filter is looking better each cleaning.
I removed the hopper to clean radiator and replaced the water plate with holes in it. It was all but gone. Reassembled & adjusted governor linkage to hopefully improve power but no change.
Next on my list is to perform a fuel consumption test using two 1.5 kw heaters as a load and measure fuel consumption using a postal scale to measure grams of fuel weight consumed in 1 hour. I can then calculate fuel consumption in grams/hp hour.
I have recorded the fuel consumption rate of my other L series Yanmars L70, L90 & L100.
I would hope this to be as good or better, we will know soon.
90cummins
/ Yanmar NS10 Hopper Cooled Diesel #14
I had a letterpress that continuous operated with that setup. Heidelburg, a Air pump was added with the elec. motor so then it would stay in motion. 1800's model. You would pull a large wheel by hand and the weight of the die plates worked in a centrifugal manor. You had lead Lettering and Numbering to print with and set a die. I still used it in a printing shop until the early 2000's.
I can see the Yanmar Marine use on that. No water pump on a Ym1700 is another example.
/ Yanmar NS10 Hopper Cooled Diesel #15
Heidelberg's are amazing. My understanding is that they are still in demand because of the quality.
@90cummins that looks like a fun engine! I will be interested to learn whether or how the specific fuel consumption is different.
All the best, Peter
2019 TerraGator 7300 Spinner truck (A61307)
2019 TerraGator...
KUBOTA U55-5 EXCAVATOR (A59823)
KUBOTA U55-5...
Crown RM6025-45 Stand-On Electric Forklift (A59228)
Crown RM6025-45...
PALLET OF ROLLERS (A60432)
PALLET OF ROLLERS...
2007 John Deere 644J Articulated Wheel Loader (A59228)
2007 John Deere...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
