OP
Lyonsjonah
I saw that gear set. 194193-31390 is the number I'm looking for. That is the going rate for them but the tractor is in almost new condition and its 4x4. It would bring 4500-5000 in my area. I did get a quote to cut a new gear and it wasn't pretty..(3000)Those Indian/Pakistani videos are unique. Keep in mind that from the 1900's to the 1950's, and even later, vehicles and equipment were made ground up with similar tools and equipment.
The welded steel may well be as strong/hard as the base metal.
The biggest problem is whether or not the tooth profile would be good enough. One could use dyes and gauges to monitor precision of hand grinding the teeth. Apparently not being used in the video, at least what was shown.
In the more modern world, one might be able to program a CNC to grind and polish the teeth. Better if one's mill was capable of matching the axis on the tooth profile.
From links above, an E-Bay ad keeps popping up. I don't know if it is the right gear set.
Used Ring Gear And Pinion Shaft fits Yanmar 194312-31300 | eBay
Replaces Yanmar OEM Number(s) 194312-31300.www.ebay.com
$915... Whew!!! But, that may well be what the gear would cost.
So, is the tractor used for $915 worth of work? Or does one wish to do a backyard kludge that could get it moving under it's own power, and doing light home duty?
Undoubtedly there are shops that can cut new gears from scratch. However, it won't be cheap.
