Yellow Hydraulic Seals
   / Yellow Hydraulic Seals #11
It has been 20+ years since I worked with Disogrin so memory is very faded but if memory is correct it was less pliable than buna n but did have some memory and would return to size after being stretched.
If I was you I would take the time to go to a place that sells hydraulic seals. Trying to figure out a seal just by its color is no the best way to go. For example, Buna-n and EPDM are both black. Plus, even seals made from the same type of elastomer may have a different hardness. Take your seal to someone who knows. They can measure the durometer and get you the proper seal.
Eric
-I appreciate you posting (thank you) but I'd already thought of this. That's the first place I would have gone if there was one in the area I trusted. Lots of people work counters, just not a great depth of knowledge most times when I ask technical questions around here. Many nice people live in this area, just not a lot of technical expertise on some subjects. I'll probably have to drive 75 miles to Knoxville for a valid opinion on hydraulic seals. If I still lived in Chicago I would have had the answer already. Life in rural Tennessee is an adjustment for some things.
17345 (A56859)
17345 (A56859)
2010 KENWORTH T800 (A58214)
2010 KENWORTH T800...
2015 Peterbilt 389 T/A Wet Kit Day Cab Truck Tractor (A55973)
2015 Peterbilt 389...
2005 International 4300 Telsta Bucket Truck (A55973)
2005 International...
202483 (A54757)
202483 (A54757)
Case 1020 25ft Draper Head (A56436)
Case 1020 25ft...
