Yet another nex BX23 owner - but with minor probs
   / Yet another nex BX23 owner - but with minor probs #11
Not sure where in Vermont you are going to vacation, but I have some lawn you can mow with my BX2200 if you would like to "play" while you are here!!!
Well, as suggested I jacked up the back of the tractor until the wheels were off the ground. With the valve stems at 12 o'clock I left off some pressure and then removed the Schrader valve (I never knew it was called that /forums/images/graemlins/smile.gif). With one tire, the "high" side, there were no problems. The valve came out easily and there was no fluid. Rotating the tire slightly did produce a trickle so I know that tire was filled properly.
On the other side, the "low" side, removing the valve produced a heavy stream of fluid. At least 1 1/2 gallons drained off before the flow slowed then stopped. This tire obviously had too much fluid. Hopeful that I solved my problem, I quickly replaced the valves, re-inflated the tires and lowered the tractor. Unfortunately however, this didn't fix it. The loader is still off about 1/2 inch /forums/images/graemlins/mad.gif.
I'm going to call the dealer tomorrow morning. I'll ask them to come pick up the tractor and figure out what the problem is. I'm hoping there is an easy solution but just not sure what to expect. The bottom line is that I won't be satisfied until until I have a level tractor. The worst part is that the dealer had six BX23's and I picked the wonky one. I'll post back with what I find out.
   / Yet another nex BX23 owner - but with minor probs #13
If the tires have calcium chloride inside, make sure the fluid covers the entire rim. This will prevent corrosion of the rim. You can by a gauge designed for fluid filled tires. They are made with non corrosive materials. The pressure will read the same with or without fluid in the tires. You won't have any fluid come out once you learn how to put the gauge on the valve stem properly. Put the gauge on squarely, press firmly, then remove quickly.
   / Yet another nex BX23 owner - but with minor probs #14
"Time for you to upgrade your ride- the BX23 has the built-on backhoe, so these jack things you speak of are from the history book!"
I'm not sure why you'd say that...
If you're expecting to depend on your backhoe stabilizors...well, that's not a safe thing to do. The jack stands are adjustable, but lock into a given height.
Just as it is unsafe to get under a car or truck on a mechanical or hydraulic jack, it's unsafe to depend on your hydraulic stabilizers when working on the tractor.
   / Yet another nex BX23 owner - but with minor probs #15
<font color="purple"> </font> Jack the rear of the tractor off the ground (¼" is plenty), <font color="black"> </font>
Roy- I think you are either over tired or oversensitive. I would say that your suggestion to jack a tractor as you referenced above would be safely accomplished with the backhoe stabilizers. A 1/4" fall? I think you have a case of BH envy!
   / Yet another nex BX23 owner - but with minor probs #16
Never get under or depend on any thing hydraulic to safely support any thing.
Hydraulic devices can leak down,
hoses or lines can bust and drop the load on you or someone else.
Safety devices are always in order when / where hydraulic and mechanical lifting devices are involved.
</font><font color="blue" class="small">( Roy-
these jack things you speak of are from the history book! /forums/images/graemlins/wink.gif )</font>
   / Yet another nex BX23 owner - but with minor probs #17
ESM,
Hope you had a good vaction in Vermont /forums/images/graemlins/smile.gif It's a nice place.
   / Yet another nex BX23 owner - but with minor probs #18
I'm sorry, I must be more hungover than usual and missed something in the translation of the instructions given to this guy about getting some of the ballast out of his tires ... did somebody suggest that he get *UNDER* his tractor to remove the valve stem core to drain the fluid?
   / Yet another nex BX23 owner - but with minor probs #19
Nope, you didn't sleep through something- but a couple of the guys seem to be worried that 0.25" "fall" when their hydraulics fail catastrophically in an instant could jeopordize the well being of all nearby. Given that I couldn't even get the toe of my boot under the tire at 0.25" off the ground - it is hard to understand where they are coming from, but there is the first ammendment you know. I'm ditching this particular thread now, as it appears boredom has prevailed and ... /forums/images/graemlins/frown.gif
Just wanted to post an update. I called the dealer this morning, spoke to my salesman and explained the problem. He didn't hesitate in suggesting that their service department should take a look at it. He said he would talk to the Service Manager and someone would contact me to schedule a pickup. Within 5 minutes the Service Manager called me back, the tractor is scheduled to be picked up tomorrow.
I'm very curious to see what they find. I remounted the backhoe today and drove the tractor around a little just to see if would have any effect. The problem is still there so at least it is consistent. I'm not sure what Kubota's policy is and I don't want to jump to conclusions but if this turns out to be anything more serious then a bad tire or loose pin or something like that then I'll ask that they replace the tractor versus repairing it. I know I'm getting way ahead of myself but it's hard not be anxious after spending so much on piece of equipment and then running immediately into problems. Based on what I've see posted here Kubota seems to be a very reputable manufacturer and I'm comfortable with my dealer as well so I'm sure it will all work out. It still sucks though!
2008 Ford Fusion SE Sedan (A59231)
2008 Ford Fusion...
iDrive TDS-2010H...
2019 International WorkStar 7300 4x4 Altec AA55 56ft. Insulated Bucket Truck (A60460)
2019 International...
2019 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A59904)
2019 FREIGHTLINER...
Massey Ferguson 9250 (A56438)
Massey Ferguson...
John Deere 6110M (A60462)
John Deere 6110M...
