Yet another version of gauge wheels
   / Yet another version of gauge wheels #11
I sure look forward to seeing how they work. I have been looking at all the posts, and am concidering something similiar for my rake.I was wondering if the wheels come with the frame setup, or just the hub and tire. Maybe even post the harbor freight number.I know the jacks are inexpensive if you catch the right catalog.
Geeze, sounds like we are vultures, looking to steal your hard thought ideas.But I like this one, there doesnt seem to be alot of ring cutting and fabrications. And the ability to adjust is infinate.
Great idea and job.Im hoping your next post will have good reports.
Allan
Just came in from the big test, dressed up our 150 foot gravel drive, played in the big ditch I dug with the BB and the dirt I spread out from the ditch. Then went over to the property next door and helped fill a trench he dug for his shop electric but never filled back in...
Results....
1. Gauge wheels are a cool, wonderful, great, gotta have accessory.
2. Jack stands work great, no problems with the adjustment moving and it was really cool to be able to jack one side up when dressing the drive to emphasize the crown and pull the gravel in from the sides.
3. Should have put the jack stands on the end of the 2 inch tube instead of on the side.
4. The Harbor Freight wheels suck.
They actually work pretty well but tend to hunt due to the geometry of the side mount, the slop of the 2 inch tube in the receiver and the not-so-precise HF wheels. Didn't really effect the function but bugged me... Kinda like a grocery store shopping cart with a wobbly wheel. Neither wheel is truly centered under the bearing but one is noticeably canted to one side. Didn't notice it when I bought the wheels but like they say you get what you pay for. I think the only thing that saves the situation is the stabilizer bar on my 3 point that keeps it from flopping side to side.
The Bull Dog stands are going to be fine and will use the same one on the 2nd generation but will need to do something about better wheels. All-in-all they work well enough that I don't feel a need to rush into the 2nd version, a good time to build replacements will be when the bearings in the wheels go out .
   / Yet another version of gauge wheels #13
Im curious as to the wheel problem. I made some gauge wheels, and the wheels sort of shimmied and spun , I was sure to make th brackets angled too. Do you think the wheels were possibly too narrow?At least the jacks worked good. I find that is well worth the investment. I plan to go that route with mine. Ill post mine when I get started on it.
Thanks for sharing your ideas , greatly appreciated. Im curious why you have concern for the placement on the side rather than the end of the tubing. Whats the thought there?
thanks ,AL
AL
   / Yet another version of gauge wheels #14
Great News Bob!
My guess is that at some point in their gage wheel life, you are going to catch something with the wheel or bounce over a rock or something that will wipe out the jack and/or wheel. Or might cant the jack at an angle. Not an issue to rebuild.
My suggestion is not to watch it too closely--just enjoy!
Ron
   / Yet another version of gauge wheels #15
RonR, what you advise is easier said than done...
Though I agree with your point, once you see what gauge wheels do, it is almost impossible to "not watch closely". Once you see a rake capable of feathering in a newly dumped pile of gravel into an existing gravel surface, watching it again and again is addictive. And, watching a box scraper perform as we thought it always should (with gauge wheels, it will) is a tractorgasm. Watching a baby tractor like a BX23 pull a full box (48") of dirt and watching more dirt just run over the top has been beyond belief and I can't watch it enough. Without wheels the box would always want to dig deeper and deeper which made me and others think the tractor could only pull a full box ... nope, it was the fact that nothing limited the box from trying to dig to China that gave that impression. Untill you experience it, it defies description.
Another unforseen benefit is that after you pull a full box, the 3PH lever actually works as we had hoped it would ... you can actually feather the dumping of the box for a really extended distance. Unfreakingbelievable!!!
Cheers!
</font><font color="blue" class="small">( Im curious as to the wheel problem. I made some gauge wheels, and the wheels sort of shimmied and spun , I was sure to make th brackets angled too. Do you think the wheels were possibly too narrow?At least the jacks worked good. I find that is well worth the investment. I plan to go that route with mine. Ill post mine when I get started on it.
thanks ,AL
AL )</font>
Hi AL,
$20.00 trailer stands are not the most precisely manufactured items in the world, throw Harbor Freight wheels in the mix and they need all the help they can get. In watching the wheels in action the offset centers made the wheels try to tilt to the inside rather than follow like they should. I think putting them on the end of the supports will improve the geometry and eliminate some of the side play which should help tracking.
   / Yet another version of gauge wheels #17
</font><font color="blue" class="small">( What can't be seen in the picture is that I didn't cut the slot for the receivers all the way out, cut the sides and heated/bent the tab over then welded the receivers to both the tab and the channel on both sides. I would guess (even with my bird poop welding) it's probably stronger than the channel by itself.)</font>
Bob,
With what you've described, I agree with you that it's stronger now instead of weaker. I
Especially on the boxblade, it will be in an area that probably sees the least amount of stress on the implement.
I really like the idea of those receivers!!
Nice work, thank your for sharing.
   / Yet another version of gauge wheels #18
Finally consumated my holy trinity of gauge wheels ... for the back blade this time. That makes gauge wheels for my 6' landscape rake, 4' box and 5' back blade. Yet again, sure sorry I didn't fab this setup long ago.
Cheers!
2021 Chevrolet Equinox LS SUV (A55853)
2021 Chevrolet...
2025 GIYI GY-X39F Hydraulic Trencher Skid Steer Attachment (A53421)
2025 GIYI GY-X39F...
UNUSED WOLVERINE MSG-11-44W 44" HYD STUMP GRAPPLE (A57193)
UNUSED WOLVERINE...
2014 Cummins ISL 320HP 8.9L 6-Cylinder Turbo Diesel Engine (A55852)
2014 Cummins ISL...
UNUSED JCT 72" HYD BRUSH CUTTER (A57193)
UNUSED JCT 72" HYD...
1837 (A51248)
1837 (A51248)
