YM1500 3pt Hydraulic Valve Assy
   / YM1500 3pt Hydraulic Valve Assy #11
Greg it looks to me like you want a part #HV 451, the old part number was 794151-45101. If not let me know and I will try to get you the part number you need.
Can anyone confirm Dick's part number? I really need to get this thing soon. 3pt hydraulic valve for YM1500D
Greg
   / YM1500 3pt Hydraulic Valve Assy #13
The part numbers are correct. They are currently not available new. They should be here soon though (at least 1 month). You will need to rebuild yours or get a good used one if you need it before that. We can help if you need it.
Aaron
Parts@HoyeTractor.com
(940)438-0386
   / YM1500 3pt Hydraulic Valve Assy #14
I wish I had the part in stock for you Greg
Did the #s come thru bad on the fax or did I not send the right page?
Ernie
   / YM1500 3pt Hydraulic Valve Assy #15
Accodring to the info that I have, this part number has been superseded several times.
From 794151-45101 to 794197-45102-X
From 794197-45102-X to 794151-45102-X
From 794151-45102-X to 794361-45100, with a current list price of $314.50
Hope this helps.
   / YM1500 3pt Hydraulic Valve Assy #16
I don't think the 794361-45100 will fit the YM1500, I can post a picture of it if anyone wants to see it. I'm leaving in a few minutes to go to Fl, but I will be back tonight. BTW the SLP is $ 285.91 not $ 314.50.
Danny
   / YM1500 3pt Hydraulic Valve Assy #17
Danny
Please post a picture, & I will go thru our parts yard here. Maybe we have one. I just got in a partial 1500-D for parts machine. (no front end)
Ernie
   / YM1500 3pt Hydraulic Valve Assy #20
Ernie, here is a picture of the 794361-45100, I don't think you will find a used one. You can see that the 794361-45100 is not even close to being the same as the control valve on the YM1500. The control valve that Arron posted is the correct one. The one that I posted is suppose to replace the old one, but I can't see any way that it will work. The only tractor that I know the 794361-45100 will work on is the 650 JD, I'm sure that there are others.
Danny
BESTWAY AG VSK35 LOT IDENTIFIER 29 (A53084)
BESTWAY AG VSK35...
2022 DRAGON 130BBL VACUUM TRAILER (A53843)
2022 DRAGON 130BBL...
CFG Industrial SAII100 (A50123)
CFG Industrial...
Tandem Axle Rear Truck Frame (A51692)
Tandem Axle Rear...
2019 CATERPILLAR 305E2 CR EXCAVATOR (A51246)
2019 CATERPILLAR...
Toro ReelMaster Pull-Behind Hydraulic Reel Mower (A51691)
Toro ReelMaster...
