ym155 transmission stuck when in gear
   / ym155 transmission stuck when in gear
Perhaps the clutch is stuck. Turning the bolt at the front of the engine causes the tractor to move forward slightly when the clutch is either depressed or undepressed. I will start working on the motor. At one time I think one of my kids put water in the diesel tank. I had tried to drain out just the water until the diesel ran free of water. However, I have not had it running since. About 3 or 4 years ago I had the injectors worked on but still no luck. Recently I still found a little water in the diesel tank I drained it completely and tried to let it dry for a few weeks. I will report if I can get the motor started. thanks for your help on the clutch diagnosis.
   / ym155 transmission stuck when in gear #12
You have a stuck clutch then.
Depress clutch.. leave it like that overnight.. use a wood block or brick.. now.. there are various ways to unstick.
Tie clutch down, Start in gear and drive around hitting both brakes.. or drive in figure 8's and hit brake on opposite sid eof turn.. ie.. turn left.. hit right brake.
I've also seen people put a mower ont he pto, and bump the starter over with a good strong battery, having the clutch tied down and pto engaged.. this usually shock it apart.
Once it dos brake loose.. slip the clutch a few times to knock off any surface rust.
For a while aftr that.. block the clutch when not in use till you get to using it regularly.
Soundguy
   / ym155 transmission stuck when in gear #13
Or can the shifter plate remain attached to the lower plate with the 8 bolts and remove both at the same time? The "lift arm assembly" does not seem to be in the way of this plate with 8 bolts.[/QUOTE]
You can remove the whole unit without taking off the shifter assy on top by just undoing the four bolts on the bottom. This is not necessary though. I agree with Normde2001 and Soundguy. You have a stuck clutch. I would first try the advice Soundguy gave before going to more "aggressive" measures.;)
I got the engine running on Friday 9/8/06, and after a little while the clutch came unstuck. Thanks again for advice. Now have 2x6 board holding down the clutch pedal.
   / ym155 transmission stuck when in gear #15
Make sure you slip it a little, and then keep it blocked till you can get some regular use on it.
good luck
Soundguy
   / ym155 transmission stuck when in gear #16
When I first went Yanmar shopping, a lot of the tractors, without a latch, had a hardwood (factory) stick in the toolbox for just that purpose.
   / ym155 transmission stuck when in gear #17
You know, I understand why they block the clutch plate down, to keep the disc from rusting to the flywheel, but it seems like after a while that would stretch and weaken the clutch pressure plate springs, and you'd have to replace that PP early...........
   / ym155 transmission stuck when in gear #18
My NH unit came with a factory wood block... And i know of some old ford tractors that the owners keep the clutch blocked permanently when not being used... ( some are on OEM clutches... )
Soundguy
   / ym155 transmission stuck when in gear #19
I guess that could happen, but I don't think there is much choice, it can happen to any stickshift vehicle. I had it happen to my new '63 406cid Ford Galaxy one time from fitting out in an afternoon rainstorm, (hurricane).
   / ym155 transmission stuck when in gear #20
Would it help to block the pedal only half way down (ie to prevent the getting stuck, while not weaking the whole thing over time)?
thorsten
Toro Workman Low Profile Spray system 200 (A50322)
Toro Workman Low...
2001 J ODell 16ft Enclosed T/A Trailer (A51694)
2001 J ODell 16ft...
RCcar RC-G2.0 Electric Golf Cart, NEW! (A52384)
RCcar RC-G2.0...
2011 Nissan Juke SUV (A51694)
2011 Nissan Juke...
2015 Ford E-350 Cutaway Van (A52377)
2015 Ford E-350...
2022 MAXXD BD14 Heavy-Duty Dump Trailer with 14K GVWR and Tandem Axles (A53473)
2022 MAXXD BD14...
