YM2210 injectors, fuel pump, problem??
   / YM2210 injectors, fuel pump, problem?? #121
Yeah, those GASKETS should be replaced every so often.. u wouldn't believe some of the condition I get them in..
Had 1 fella GRIND DOWN a copper penny & drill a hole thru it.!!! No kidding..
I get them in double & triple stacked..
I sure hope the gasket is/was all it is..
I just got some new ones, so i will put a new one on tonight and see but im sure this is it. I bet you see all kinds of crazy stuff..
Thanks again for all the help!! :drink:
   / YM2210 injectors, fuel pump, problem?? #123
Remember only tighten your fuel cap tight enough to not vibrate off
   / YM2210 injectors, fuel pump, problem?? #124
Those bleeders originally used a plastic ring. We always had problems with them leaking so we started to use orings there (at the suggestion of a long time customer) a couple years ago (I need to fix the website description & picture). I have not heard of a single problem reported since. The key though is to just not overtighten. You just snug them up. If you crank down on them like you would if they were a copper washer then the oring will just mash out the side and can leak. Just snug them up like any other oring fitting and it will never leak.
If it was a pressurized system then that would be different and would certainly need something like a copper crush washer. This is just gravity fed.
Orings are very commonly used on fuel bleeder screws.
diesel bleeder screw - Bing images
   / YM2210 injectors, fuel pump, problem?? #125
Over tightening is my middle name.. Why they would go from plastic to rubber makes no sense to me.. A simple crush washer would have been a better idea since it doesn't matter if you crank them a bit.. One persons snug is another mans loose..
   / YM2210 injectors, fuel pump, problem?? #126
Crush washers, at least in my experience, can be finicky. Especially if you loosen and tighten them much (like a bleeder screw).
   / YM2210 injectors, fuel pump, problem?? #127
Aaron.. not to bust your hump BUT.. those Oring uses have a groove for the oring to sit & seal in..
The bleed screw on the inlet banjo bolt doesn't, its just a FLAT surface..
The "plastic" seal was purely for a manufacturing cost standpoint..{cheap}
   / YM2210 injectors, fuel pump, problem?? #128
I don't claim to be an expert by any means and I'm not arguing with what you are saying at all. I do know that we had a lot of problems with the plastic washers (maybe it was just a bad/old batch but they were trouble) and had no problems that I can recall since switching to orings.
I will investigate to see if I can find a better solution though.
I'll have to take another look tomorrow but I thought those bleeder bolts had a recessed groove also.
You can kind of see a recess below
BANJO BOLT ASSBY: Yanmar Tractor Parts
   / YM2210 injectors, fuel pump, problem?? #129
Yanmar didn't. Aaron said "we started to use orings" referring to Hoye Tractor Co. Which is one of our main supply source for parts for our old yanmars. Aaron works at Hoye , so when he says that he is referring to his company there.
   / YM2210 injectors, fuel pump, problem?? #130
Got it..
2026 Hillcrest Dump Trailer (A56858)
2026 Hillcrest...
White Metal Roof Panels (A55758)
White Metal Roof...
1000000 (A47477)
1000000 (A47477)
2004 TRAVIS BODY & TRAILER DOUBLE ALUMINUM BELLY DUMP COMBO TRAILER (A58214)
2004 TRAVIS BODY &...
500BBL WHEELED FRAC TANK (A58214)
500BBL WHEELED...
2018 Elgin Broom Badger Sweeper, Kubota Turbo Diesel Engine, High Dump, Dual Tilted Gutter Brooms... (A59076)
2018 Elgin Broom...
