I pulled the fuel bowl today when I drained the tank and replaced it with different fuel. That doesn't mean it isn't leaking still, since I may have reinstalled it the same wrong way as before. I don't think the fuel bowl is the problem, but I'll see if I can find a replacement filter and carefully check the bowl, too.
What color was your smoke, Gary? This is dark gray when at full throttle with no load. I can drive around in high gear, but it doesn't really have any power.
For clarification, Winston1: I don't think it's the fuel itself. What I topped off with was fresh from the pump, and went into my pickup at the same time. I've driven 150 miles in it since then. I replaced that fuel with diesel from another station today, and the same symptoms appeared. I'm trying to get all the low-hanging fruit, which is why I don't have an air filter on it at the moment, to eliminate that as a possibility, and why I used two sources of fresh diesel, and removed the muffler.
I guess it's time to move on to more involved levels. I don't have a service manual yet, but have seen valve clearances are supposed to be 0.008 on the intake and exhaust, as well as 0.006 for both. The only numbers I've found for head bolt torque is 127 to 133 ft-lbs. Are those measurements correct, are the units supposed to be Newton-meters? (That would work out to around 97-98 lb-ft of torque) To what specification are the injectors supposed to be torqued?
I'm getting a bit discouraged: This was supposed to be a simple, straightforward re-assembly to get a tractor to use around the property. It has become a source of frustration instead. Thank you to all who have helped me so far, I really appreciate your assistance. Merry Christmas.
