YM240D front axle shim wear
   / YM240D front axle shim wear
rScotty, thank you so much for reading through the thread and posting a very informative reply. I agree with you that PO at some point did something and I am glad I asked this question as it did not feel right.
Well, s**t. I guess I have to do it and do it right (I like my 4WD). I also think finding used one could cause a separate set of problems (also sourcing that is hard here in CA/NV).
Immediate question: how will I be able to measure the backlash between these gears - the way that 240D front end is assembled, its like a puzzle - I had to take knuckle entirely off to pull the axle/cover and there is nowhere to stick a tool or even see the gears once its together... :scratchchin: I could assemble the cover with axle, without the knuckle body (#43 in this drawing: 4WD EXTERNAL ^: Yanmar Tractor Parts). Temporarily bolt that assembly on (since it conveniently has holes to do that) which will give me access to measure and adjust. Then once I got the spacing correct, remove that assembly and complete it with the body, then re-attach the whole thing. Does this sound right? Any glaring issues with this approach?
Do you have ID/OD handy for these shims? I am guessing it should be the same ID/OD as SC-4161 spacer, just called Hoye and its 42mm ID, 48mm OD. Does this sound right?
I also just got original service manual, but it is at home (heading to work now). Will go over it tonight and ask more questions if I have them.
For what it is worth the shim numbers I gave you from Hoye are straight out of the 195/240 parts manual. They are different for the 195 but the ones I showed are for the 240. This I&T manual has instructions for your 4 wheel drive. Original YANMAR I&T Shop Manual YM135 155 195 24 33 D Manual No. YM-1 | eBay
winston1, thank you - I saw those and when I called Hoye to ask today they didn't have any. I also don't have thicknesses needed, and wanted to get a kit instead. I asked the parts advisor to measure SC-4161 spacer instead so I can get them from McMaster-Carr (rScotty's advice).
Also I, at this point, have armed myself with all manuals, including the one you linked.
   / YM240D front axle shim wear #14
Sounds like you have it under control. :thumbsup:
For now. And I couldn't have done it without your advice :)
   / YM240D front axle shim wear #16
OK! Well you sound like you can do it. It sounds to me like you know what you are about. One thing at a time....is yours the OEM Shop Manual? My shop manual for the 195 is for 2wd. I also have the OEM shop manual for the 135D/155D which is what I am working out of. So the procedure will be correct, but the relative shim ID/OD may not.
I think we need to be working off the same exploded diagram and parts book regardless of which one we choose....
Backlash: If you can't see it, no problem. You can go by this rule: On dry contact, if you can feel play at all but not hear any click, that is about .002". At about .004" most people can hear a metallic "click" when feeling for backlash. Yanmar's preferred backlash seems to be .005 to .012", and I bet you can estimate that close enough. After all, what you are trying to do is get some backlash without too much. The real goal is that when the backlash is correct, the engagement of the gear faces should be centered in the middle of the gear teeth. You can check that with machinist's dye, but easier to just bet via backlash. There's some nice pictures and discussion of setting up gear engagement in the OEM shop manual too. I haven't checked on aftermarket shop manuals to see how they compare, but I've got one and will take a look.
Be aware that there are not only shims in the axle, but also a set of shims on top where the steering knuckle connects to the king pin.
Also...some of the bearings in the axle are single sided oil shield type. Hard to find. Buy a double sided shielded bearing and remove one shield with a probe and hook.
rScotty
   / YM240D front axle shim wear #17
I took a look at my I&T shop service manual for the YM135 through YM330 both 2wd & 4wd models. The cover says Manual NO. YM-1. Copyright is 1985. 82 pages. I didn't compare anything line for line with Yanmar's OEM shop manual, but this I&T manual is well-written. It has excellent coverage of the front axle and nice illustrations as well.
rScotty
rScotty
I have the I&T manual for YM135 through YM330D, and just purchased OEM shop manual (but I haven't seen anything about front end in there). I am not sure which version it is for (and not sure which version is my tractor really, but that is whole another story). I also have OEM parts manual through last version, printed in 1990s. I can post photo of diagrams here if you want to take a look.
I am *really really* hoping not to have to take apart the rest of the front end. Can I get away with that?
Bearings that came out of the assembly look good to me (you can see earlier posts w/ photos), although a bit crunchy now. I was thinking if I can wash that sand out, I can maybe re-use them, but I didn't see shields (maybe because they are not OEM replacements by PO?). Nevertheless, I preemptively ordered all spacers, wear collars, seals, and bearings from Hoye to do this job, so if you recommend replacing, I am ready for that too. I read somewhere else to pull shields out if there is no channel for gear oil to travel through, but haven't seen anything about pulling just one side out. Can you explain why to pull only one side?
   / YM240D front axle shim wear #19
Pulling both shields out on your installation would be fine. Those bearings are submersed in oil. I am sure the correct procedure would be to take the rest apart. Not saying I am correct but if I believed vertical bearings and gears were all good I would likely go for the stub axle only. I have messed with a bunch of backlash/gear contact through the years and it can get quite complicated. Having said that I would put the amount of shims on your stub axle as close to the original and install it with a couple of bolts and just feel by turning the stub axle for a little backlash. It is my belief that you pay close attention you feel it and differentiate it from the vertical shaft backlash. As long as you can feel a small amount you will be ok. You can add or take away shims to get that small amount of backlash. Again, probably bad advice, but no charge. :D
   / YM240D front axle shim wear #20
Sounds to me like we have the same books - or close enough. If something is different then no doubt we'll figure it out.
If you can convince yourself that nobody has been into the center section of the front axle then I see no reason to take it apart. Take a close look at the center gasket and bolts to see if they've been apart. Then I'd check the backlash out at the axle ends vs the input pinion by twisting them by hand and making an educated guess as to backlash using what we've already said. If that feels OK I'd might try to gently flush it to get any metal bits out via the central drain plug. And would definitely plan to change oil a couple of times soon after it gets going.
ONE-SIDED SEALS:
You've probably noticed that some of the Yanmar front axles are designed to be three separate oil reservoirs - each with it's own fill port and drain. I'm not sure when Yanmar deliberately went to that 3 separate oil reservior idea. They kind of played with the idea for awhile. You can tell the model axles that bought into the the idea because they tend to have drain plugs at the bottom of the outer gear housings next to the front wheels.
most of the red painted YMs had those drain plugs but I'm not sure about the older green machines like the YM240D.
Some cross-over designs didn't have the outer drain plugs but could drain the spindle housing by pulling one of the bottom bolts that mount the bottom plate of the spindle.
So why separate the oils? Well, all this is speculation on my part. It might be true and might just be my own overactive imagination. But I don't think the 3-separate volume axle system is so much to keep the oils from mixing as it is to slow down wear particles from migrating from one area to the other. Whatever, it's just one more reason why that whole front axle design is crazy clever. Think about it.....the single-sided bearing shield allows oil to lube & cool the bearing, while blocking any metal particles, dirt, and debris from making its way between the different areas. That confines any catastrophic failure debris to one area instead of all areas. Not only is it a nifty idea, but they get it for free by actually throwing away a part (one shield). That's cheaper than free!!
Oh....It's easier to pry off one side shield if you use shielded bearings, not sealed bearings. And shielded bearings allow oil to flow though more easily than sealed bearings do. But please don't overthink this. I doubt it is going to change anything if you use completely open bearings - they'll work fine. You just lose out on a clever way to separate dirt & debris transfer if a problem ever does occur. Other than that, I can't see why it would matter. No biggie.
HISTORICAL NOTE
Yanmar invented that front combination steering and driving axle. They patented it, and for years only Yanmar had that axle. Of course now it is the standard axle on every brand of compact tractor. And after all, that is what patents are designed to do. Patents trade a limited period of exclusive use in exchange for publishing a better design.
The result of that is that today even my Kubota (Yanmar's arch rival) uses Yanmar's dual bevel gear front axle design. I'd like to shake the hand of the guy who designed it. You really have to go back to some of the front wheel drive mechanisms that preceeded Yanmar's front axle to fully appreciate it. For comparison, look at the sliding wear and limited turning angles of FWD designs using Reseppa joints and other CV attempts. Trying to figure out how to drive a front wheel while allowing it to rotate about a kingpin led to some real ugly front axle attempts.
NEW BEARINGS?
As for ball bearings... Come on now; use new ones! Bearings are cheap. Radial ball bearings aren't Yanmar parts; they are universal parts. Every manufacturer buys them from a bearing supplier and specifies them by bearing number. Nobody makes their own. I think Yanmar uses a lot of 62xx series ball bearings, which just might be the world's most common bearing spec. The common sizes of bearings cost less than ten bucks each retail - and that's even with paying extra for the dual shielding and about a 50% for a really top quality bearing with brand names you've actually heard of before....names like SKF, FAG, NSK, etc....Or you can buy cheap knockoffs for half the price but why bother? And why not change them? Especially since yours already feel rough. In your heart you know not worth it. Try McMaster.com for competitive bearing prices.
enjoy,
rScotty
1982 SHOP BUILT GOOSENECK 24 FT TRAILER (A58214)
1982 SHOP BUILT...
2016 Ford F-150 4x4 Crew Cab Pickup Truck (A56858)
2016 Ford F-150...
2025 FUTURE X-DM43 SKID STEER DISC MULCHER (A58216)
2025 FUTURE X-DM43...
Hot Pressure Washing Equipment Set (A56857)
Hot Pressure...
UNUSED FUTURE XLA59 - 59" DRUM SPIKE LAWN AERATOR (A52706)
UNUSED FUTURE...
2025 J & C Suppliers Enclosed Trailer (A56859)
2025 J & C...
