You know it is cold on the farm when...
   / You know it is cold on the farm when... #41
Hard on those underneath too, we get the same thing but on extremely hot days, almighty crack and off comes a big limb from up high, the koalas do not enjoy the ride down either.
Koalas are nothing but a bunch of punks.
   / You know it is cold on the farm when... #42
They are vicious little sods except for the 'cuddly' ones you see on TV that have been brought up in captivity.
   / You know it is cold on the farm when... #44
Pure ethylene glycol freezes at about 8 degrees F. With the other additives that are in "antifreeze" it will freeze somewhere from about 0 F to -10F. Mixed properly with water the freezing point will go down to almost -49F I totally believe cans of antifreeze being frozen solid. NO BS.
I was a Chemist in my first life; and as I recall, mixing ethylene glycol with water, say 50/50 lowers the freezing point of both quite a bit. I never thought to check out his story, but I never doubted it. As a practical matter, I hate Winter and cold weather so I think more in terms of the Caribbean than I do of Alaska.
   / You know it is cold on the farm when... #45
...when you go to blow your nose and break off an icicle.
   / You know it is cold on the farm when... #46
Anti-freeze doesn't freeze in the Caribbean. It's used in drinks.
   / You know it is cold on the farm when... #47
When it gets really cold you can hear the nails popping out of the roof trusses.
Steel contracts at a greater rate than wood as it gets cold.
I have observed this phenomena in every newly built house that I know up here in cold Canada.
Generally occurs when the cold hits -30 or so,
   / You know it is cold on the farm when... #48
When you forget your handkerchief and this happens:
   / You know it is cold on the farm when... #49
When you leave "wool footprints" out on the front porch. And RUIN a good pair of wool socks.
   / You know it is cold on the farm when... #50
Winter in Amarillo Tx. 2009
My wife says we need to get indoor plumbing.
2008 Isuzu NPR-HD Landscape Dump Truck (A46683)
2008 Isuzu NPR-HD...
2015 Ford F-550 4x4 Extended Cab Auto Crane HC-7 Service Crane Truck (A46683)
2015 Ford F-550...
2014 Utility Trailer 4000DX 53ft. T/A Dry Van Trailer (A48081)
2014 Utility...
I&J 3pt 2-Row Cultivator (A49251)
I&J 3pt 2-Row...
More info coming soon! (A46684)
More info coming...
Smith Equipment 72in Hydraulic Sweeper/Broom Attachment (A46683)
Smith Equipment...
