rScotty
Super Member
- Joined
- Apr 21, 2001
- Messages
- 9,722
- Location
- Rural mountains - Colorado
- Tractor
- Kubota M59, JD530, JD310SG. Restoring Yanmar YM165D
Yes, you can see how it would make sense if the spool was not milled correctly for the body. It wouldn't take very much of an error to make all kinds of odd things happen with the fluid flow. But the same could be said of the position of the ports in the body...or even about which internal ports are selected to be active as the spool is moved. Or for that matter a leaking relief valve that leaked more than the spool position was trying to flow might do be able to deadhead the flow.
Selecting an alternate flow path is what those open-vs-closed system PB plugs do in other brands of valves. In those directional control valves, using the wrong plug in the wrong system will deadhead the flow because then the valve can't simulaneously open a working port and a return port. But unlike your situation, when that mistake is made it tends to deadhead the pump regardless of valve position. It sounds to me like yours is only at certain positons.....and that might be the key.
I'm still not completely sure how Youli's valve design does it's job, but in an attempt to educate myself a little more I went to the Youli site yesterday Products | Youli-America and read up on their valves. Very impressive site. Absolutely great illustrated pictures and in color, too. I haven't seen color illustrations that nice in the tractor world since the old Yanmar Technical Publications Powershift Booklets from the 1980s.
From there I went over to the Allied Valve site & others to read more on set point and back pressure. This is fun stuff.
The result of all this study isn't that I know much more than before, but my confusion is in nice colors and I'm likely to spout hydraulic fluid if pressed.
rScotty
rScotty
