Your favorite lawn and garden tractors Past and Present
   / Your favorite lawn and garden tractors Past and Present #11
Mith said:
(100 and 200), 300, 400 and 500 series Wheelhorses. Great bunch on Wheelhorses. Built like the old ones, but up to date.
As Tommy said, one of the very few modern tractors that are as well built as the older ones. You could buy a new 300 series up until about 2-3 months ago.
I changed mine to make it 52" wide with duals, not tippy atall now. It takes a beating and keeps chugging along. It's starting to show its abuse, but its OK.
okay...you got me. How do you hold the outside wheels on?
   / Your favorite lawn and garden tractors Past and Present #12
The John Deere 140H3, 318, and 332 are my favorites. I am lucky to have one of each.
Ken
   / Your favorite lawn and garden tractors Past and Present #13
Ken
I like the hydraulics on the 140. Looks to be a pretty nice setup
   / Your favorite lawn and garden tractors Past and Present #14
A Deere 140H3 would be my all time favorite, but I also love the old Deere 300 series, currently have (2) 316s. I have a special fondness for old IH Cub Cadets as they were the first tractors I ever used. Honorable mention to the Ariens GT series, Case/Ingersoll tractors (back in production thank goodness!) and the Gravely 4 wheel tractors. Out of all of them, the Gravelys might have been the strongest if a little quirky to use.
   / Your favorite lawn and garden tractors Past and Present #15
My favorite would probably have to be the John Deere 318. A very sturdy and well build tractor. I also like the John Deere 400 however it tended to be a little less sound mechanically than the 318.
   / Your favorite lawn and garden tractors Past and Present #16
Growing up, my dad would haul home about anything that would mow grass AND was cheap. Nothing ever lasted more than a few months with his wild son at the controls. (That'd be me) In 1980, I took over the purchasing of the lawn mower fleet. (My home was directly next to my parents) First thing, I bought a Case 222. It was a tank! Best mower I'd ever had the pleasure of running EXCEPT for one glaring glitch. The exhaust system kept falling off. It would release heat under the hood. That was it's downfall. In 1982, I bought what was (is?) the finest example of a lawn and garden tractor I've seen to this day. An INTERNATIONAL HARVESTER Cub Cadet 682. (One of the red ones) Instead of being an over-glorified lawn mower, it was a small tractor. Hydrostatic tranny, enough built-in weight that it rode like a Cadillac, and parts that were designed for the long haul.
And if I'd never let my bro-in-law borrow it, the 682 would have lasted longer than me. But that was my fault for letting him use it. Those old Koehler (sp?) Magnums (series I) didn't hold much oil. (Seems like it was 3 pints) It developed a leak through the front main seal while he was using it. He said that since it was "just a little bit of oil leaking out" he didn't think that'd be a big deal. Well, it was. When he returned it, the engine sounded like someone beating on an empty oil drum with a ball peen hammer. A rebuild would have set me back about a grand. (needed new PTO clutch as well, after it got oiled down) Complete new Koehler Magnum series II was almost $1500. The tractor itself was worth around $1500 at the time. I didn't have the time, nor the inclination to do the work myself, and ol' Bro-in-law sorta disappeared come time to pay the piper.
Enter John Deere 265 circa 1991. Good mower, just NOT a Cadet 682. It's still plugging away, but all things being equal, I'd rather have that 682 back. (Got $850 trade on the Deere even with trashed motor)
Shoulda kept the Cadet and found another motor. Again, my mistake.
   / Your favorite lawn and garden tractors Past and Present #17
My favorite I suppose was an old 1957 ? Simplicity VB walk behind Garden Tractor. Spent many an hour behind that little beast growing up.
I now have an old Gravely 812 which I like a lot.
Ben
   / Your favorite lawn and garden tractors Past and Present #18
Dang, I just completely rebuilt a Kohler Magnum. Bore 0.030 over, New Rod, piston, Chrome Rings, new governor, and carb rebuild for right at 250 in parts. You could have taken the clutch apart and cleaned the face with brake cleaner. Ive done it before, worked fine. Ive had em soaked in oil, and be fine.
I think you probably had a Kohler K series, basically older, Identical to the Magnum, except it had points.
For what its worth, Ive got an 8hp Kohler, and it holds over a quart. Ive got a 10hp Magnum, and it takes right at 2.5 quarts. My dads Cub 1200 has the High Volume oil pan, and it takes alot too. Could be you had the wrong dipstick or something...?
   / Your favorite lawn and garden tractors Past and Present #19
Past favorite machine:
Kubota G4200.
We had one of those at our old church for mowing the larger areas around the church grounds like the softball field, and next to the parking lot and the ditch line. That diesel was a beast and even a bunch of high-school kids couldn't kill it. It had no problems cutting a mixture of bahai and other oddball grasses that was rather tough,but you could drop the deck all the way down and run it wide open.
Present favorite machine:
My new G2160.
Compared to everything else I've sat on and used-this thing is the king for sure. Amazing power and speed with great handling and an excellent cut.
JL
   / Your favorite lawn and garden tractors Past and Present #20
It was a Magnum series I. The crank was trashed. It would have needed a crank kit in addition to all the other parts. The clutch ended up with a burnt out coil. It had to be replaced. Parts alone listed out just shy of $800, and then the machine work required.
I still have the old manual on the 682. It states 3 pints as crankcase capacity. (17HP Magnum series 1)
Add to all of that, I didn't have the time to do the work myself. (My father died 2 days after the mower returned in pieces) I would have needed to get it done by the local Cadet dealer. $$$$.$$X10!
Utility Trailer (A52377)
Utility Trailer...
2014 TEXAS PRIDE GOOSENECK (A53843)
2014 TEXAS PRIDE...
2018 UTILITY VS2RA 53FT REEFER TRAILER (A54607)
2018 UTILITY VS2RA...
2019 Dodge Durango AWD SUV (A53424)
2019 Dodge Durango...
2021 Allmand Bros Maxi-Lite II Towable Light Tower (A52377)
2021 Allmand Bros...
FELLOWS PAPER SHREDDER (A53843)
FELLOWS PAPER...
