Your thoughts on Brush Grubber products
   / Your thoughts on Brush Grubber products #11
I have a Brush Grubber with 6" capacity. It is heavy. Tiring to open the jaws.
I prefer a 5/16" chain with a slip hook to choke grip trees. Lighter, simpler and always on my tractor.
   / Your thoughts on Brush Grubber products #12
A 3" diameter steel pipe with teeth cut into the end and a length of chain welded to the side works just as well and is very cheap. Loop the chain around the tree and through the pipe with the teeth touching the tree, hook your chain's grip hook up to the small chain you now have protruding from the end of the pipe and pull. It won't slip off. ;)
2016 Crane Carrier Co. Low Entry New Way 31ASL 31Yd Side Loader Garbage Truck (A51692)
2016 Crane Carrier...
2017 MORBARK BEEVER M12RX PORTABLE WOOD CHIPPER (A51247)
2017 MORBARK...
2010 DODGE RAM 2500 FLATBED TRUCK (A51247)
2010 DODGE RAM...
JOHN DEERE Z960M LOT IDENTIFIER 93 (A53084)
JOHN DEERE Z960M...
UNUSED AGT SDA 140W WHEEL LOADER (A51247)
UNUSED AGT SDA...
E-Z-Go Freedom TXT Electric Golf Cart (A51694)
E-Z-Go Freedom TXT...
