ZD 1211 recall ?
   / ZD 1211 recall ? #1
Rmart30
Platinum Member
Alabama
Currently have Kubota L4600HST, Kubota M7040, Kubota M8540, two Massey 265's, Massey 230, ...... Had Long 510, Mahindra 3510.Ford 4000, Deere 4230.
Anyone else gotten a notice for a reserve tank nozzle defect? Anyone had it done and what was the fix?
   / ZD 1211 recall ? #2
A year or so ago. Some radiator overflow tank caps did not have the hole go thru to the hose. They send you a new cap to put on. My old one was fine but put the new one on anyway because it has a mark on it to let you know it is updated.
If that is what you are referring to. Don't know of another.
   / ZD 1211 recall ?
This one im pretty sure says fuel tank. I got notice in the mail Saturday.
   / ZD 1211 recall ?
Just called a dealer … the recall consists of them checking the outlet at the bottom of the reserve tank that supplies the crossover hose to the main tank for obstruction.
This is done by draining the fuel and inserting a 3.5 mm drill bit into it. If the bit slides in fully its good and they do nothing to it. If it doesn't they will open it with the bit to relieve any over molding of the plastic.
   / ZD 1211 recall ? #6
Yes about a year ago
   / ZD 1211 recall ? #7
There are two campaigns. One for casting flash in the recovery tank cap that can block venting and a later one that came out in the fall for blockage in the recovery tank bottom nipple that accepts the radiator overflow hose.
   / ZD 1211 recall ? #8
I got a new cap in the mail then a recall letter for the fuel tank but mine is working fine so I hadn’t hauled it 25 miles to the dealer.
   / ZD 1211 recall ? #9
I got the cap but ive seen nothing on the other recall does anyone have the details on the other recall
2014 ARISING INDUSTRIES ENCLOSED TRAILER (A47001)
2014 ARISING...
AGT Mini Excavator Attachment Set (A46443)
AGT Mini Excavator...
2012 TYTAL 130BBL VACUUM TRAILER (A47001)
2012 TYTAL 130BBL...
2022 ALLMAND LIGHT TOWER(INOPERABLE) (A47001)
2022 ALLMAND LIGHT...
2005 Pitts LB35-33 Lowboy (A47371)
2005 Pitts LB35-33...
Small Brillion Cultipacker (A47809)
Small Brillion...
